Old 09-09-08, 09:15 AM   #11
Default Re: Clutch lever question..
Bypass the thing, they're only good for leaving you stranded somewhere wet and cold anyway...
Old 09-09-08, 09:15 AM   #12
The Guru
Not sure yet.. just wanted to know if this would fit 1st. Clutch switch will be my next post..
Old 09-09-08, 11:48 AM   #13
Dangerous Dave
What are you going to do about the clutch switch?
As Chris said, bypass it.
Old 12-09-08, 09:20 AM   #14
The Guru
Easiest way to bypass it?
Old 12-09-08, 09:31 AM   #15
Stick a paperclip in the end of the connector then blob the end with silicon
Old 12-09-08, 09:31 AM   #16
jambo
jambo's Avatar
You can just use a bit of wire to go from one side of the connector to the other, I've used about an inch of multi-core electrical cable before.
Personally I think it's worth using the safety cutouts, and if they go wrong about 6 inches of insulating tape and an inch of wire has you on your way
Jambo
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
need clutch lever and a gear lever! matt90 Stuff Wanted 0 23-11-07 02:08 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
clutch lever and front brake lever Quiff Wichard For Sale - SV's and SV related items 4 19-03-07 12:05 AM
