#11 |
Hugger, then use ACF-50 on the engine.
#12 |
Hugger, as said coming to the time of year were muck, water etc will get sprayed up at your shock, so protect it! Have a look on eBay for huggers, i've just sold mine on there.
#13 |
Bit of corrosion on the engine doesn't hurt things, the shock shaft corroding and popping seals does have an effect!
#14 |
Right so which one to go for. I think i will just have to go for the black ones as i cant afford to get colour coded just yet.
Which make are the best and where to get them from. PS i keep checking ebay but cant find any for a k6. |
#15 |
The best hugger I've seen is the Genuine Suzuki one, but its not cheap but you will get a colour coded on if you go that way.
If you want to keep cr*p off your bike, then fit a fenda extenda on the front mudguard, it might look horrible but it really does keep down the amount of muck through up off the front wheel. A K3 one wont fit as they moved the toolbox on your model, so IIRC you want a K5 onwards one otherwise it aint going to fit.
#16 |
Do you ride in the rain, if not get the belly pan if thats what you really want.
Either way I would get the hugger first, I had an OEM one fitted when I purchased my SV, was better than the majority I saw.
6.67300 × 10-11 m3 kg-1 s-2 |
#17 | |
Been looking at suzuki ones but i think they are out of my price at moment. Thanks for the info about K3 not fitting. ![]() |
