Old 12-09-08, 11:53 AM   #11
gettin2dizzy
Default Re: Chain came off HELP!
Bummer.
You got fuel? Is there any visible damage to wiring?
Old 12-09-08, 11:53 AM   #12
pencil shavings
anyone know of where to get the engine casing? ebay is dry and i dont have the part number!! thanks
Old 12-09-08, 11:56 AM   #13
pencil shavings
Originally Posted by gettin2dizzy View Post
Bummer.
yep, plently fuel.
there are acouple of wires that have been servered by the chain, so thats what i think it is.
need to get a engine cover and start working on it to see what happens when i start taking it apart and see if i can fix the wires!
have the day off today and tomorrow so hopfully I can get somthing achieved, but need the part....
Old 12-09-08, 12:08 PM   #14
Grinch
All I can say is contact your local dealer and hope they have it in stock.
Looking on the Alpha sports site it appears to be part 10 - 11351-19F50 COVER, MAGNETO.
Old 12-09-08, 12:26 PM   #15
pencil shavings
thanks grinch, Ive ask for avaliablity and should know soon.
I will keep you posted on the progress.
Old 12-09-08, 08:22 PM   #16
ricky_t
Sorry to here about your incident.
How much slack should there be on an sv650s when just sitting on its stand. Mine is about 1 inch and has not been adjusted since april when a new tyre was put on.
Old 12-09-08, 08:51 PM   #17
fizzwheel
fizzwheel's Avatar
Slack should be 25 - 35mm IIRC, if you still have a standard chain guard on it, there should be a little sticker on there that tells you how much it should be adjusted to.
Yours sounds about right IMHO.
Old 12-09-08, 09:34 PM   #18
xXBADGERXx
What bits do you need?
Well apart form a new chain and sprocket set which you might be able to get from a dealers, or order now for a quick delivery from B&C Express.
+1 , I ordered a DID X ring Gold Chain and Carbon Steel JT sprockets from them and they arrived damn quick for the measley postage they asked for
Old 13-09-08, 08:22 AM   #19
Baph
You might have torn the sidestand cut out wires with your jumping chain, but I don't know how they route on the pointy's.
The only wire that I remember being down there is the side stand cut out. It's got a mount that uses one of the sprocket cover bolts, and feeds down pretty damn close to the front sprocket.
I don't think that's your issue, unless the wires are touching each other (so you get to turn over, but the vibrations kill the engine when the wires contact).
I'd start looking elsewhere for the starting issues - start by removing the plugs & making sure they work (that'll tell you if the problem is electrical).
Congrats on manhandling it to the side of the road, and thankfully it sounds like there wasn't as much damage to the bike as there could of been.
Old 15-09-08, 01:46 PM   #20
pencil shavings
right, had a proper look at the bike with my uncle the other day, found what the probelm was..... and none of you were right!! Im going to do a full post now with pics
Chain Always Loose, New Chain? RGSPro SV Talk, Tuning & Tweaking 8 02-07-10 10:05 AM
Cam Chain jambo Stuff Wanted 6 05-08-08 10:28 AM
Chain on the way out? krhall SV Talk, Tuning & Tweaking 5 20-04-08 07:14 PM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
