Old 14-09-08, 01:50 PM   #11
Blue_SV650S
Default Re: Weird vibration under very heavy braking
Originally Posted by chakraist View Post
USD - and what does coil bound mean? I was doing some more very scientific testing and it happens only when I stamp on the back brake.
Thanks very much, that's very interesting, it's definitely only on the back brake that it happens so who knows?
Its the back chattering away then
Coil bound is when the spring is fully compressed ... i.e. all the gap between windings is used up and they touch each other, obviously when this occurs, the front won't be able to compress any further.
Old 14-09-08, 02:01 PM   #12
chris8886
chris8886's Avatar
http://www.apriliaforum.com/forums/s...d.php?t=161457
This may help you. I also get something similar, can deffinatly feel its from the front though. Its as the brakes grip and then let off a little as the grip goes on the disc because of the muck and grime causes a little vibration.
Anyway read it and see what you think.
Taa.
when people on that apprillia website are talking about "rotors" are they talking about brake discs?
i have found in the last couple of weeks that i'm having a similar sort of problem.
AR08 to AR13-QUALITY!
Old 14-09-08, 02:05 PM   #13
chakraist
Yeah, does seem like the back chattering- if I continue to brake harder the wheel slides. I am a big old chap as you know so this might have some increased effect. Cheers!
And I believe that yes, rotors refers to brake discs. Not 100% though.
Old 14-09-08, 02:37 PM   #14
Dangerous Dave
If the conversation is wheel/brake related then yes, across the pond in the USA they call brake discs 'brake rotors'.
Old 14-09-08, 03:09 PM   #15
ThEGr33k
Whats the chain like? If its full of tight spots then if the back wheel has little weight on it then this could cause vibration! So check the chain and wheel alignment and oil it as needed.
Old 14-09-08, 03:33 PM   #16
Back wheel chattering at limit of grip when stamping on the brake isn't really that catastrophic a sign.
Blue, I was fairly sure that the SRAD forks will hit their stops and bottom out properly before the springs become coil bound?
Old 14-09-08, 05:00 PM   #17
Blue_SV650S
Dunno, either way you run out of compliance!!
Old 14-09-08, 05:20 PM   #18
Yarp. I go on having 10mm left over travel when braking hard as possible, that's set using the preload with the compression pretty soft, (but not so soft it dives past...) then firm it up to make dive more controllable. Seems to work.
vibration rallyjon SV Talk, Tuning & Tweaking 5 24-08-08 08:26 AM
Weird vibration, possible ABS? KillaSV SV Talk, Tuning & Tweaking 20 28-11-07 06:49 PM
Front end chatter on heavy braking - wtf? thor Bikes - Talk & Issues 16 18-05-07 10:18 PM
Vibration Grinch SV Talk, Tuning & Tweaking 7 12-01-07 03:17 PM
Vibration. joelowden SV Talk, Tuning & Tweaking 7 19-07-05 07:30 PM
