Old 15-09-08, 08:07 PM   #11
joshmac
Default Re: Bang!!
Originally Posted by adamsimmons View Post
I had a similar problem to this not so long ago, and I know it sounds wierd but it ended up being the stand switch and front brake light switch. It was causing a short on the ignition circuit and causing the bike to cut out every so often, more often in the wet first of all then did it all the time until it kept on blowing the ignition fuse as soon as it was started. I replaced both of these and haven't had a problem since, been running fine now for 2 weeks with out a hiccup.
I hope that this helps
Would it actually cut out long enough for you to have to restart the bike, or was it just for a split second before backfiring?
Old 15-09-08, 08:15 PM   #12
joshmac
Default Re: Bang!!
It won't/shouldn't be the reg rec...all electrics would die, on my black sv i used to be able to flash the lights and make it backfire
That sounds cool.. Flash bang
It won't/shouldn't be the reg rec...all electrics would die...
That's what makes me think the reg/rec is OK.. lights, horn, indicators etc all appear to be fine.
Do you think it's possible that it's all down to the alarm.. immobilising for a split second, causing it to backfire when it reignites.
And now just packing up all together?
Surely if this was the case though, I'd have to disarm it with the fob (which I can't do ffs), no?
Old 15-09-08, 09:36 PM   #13
Default Re: Bang!!
You have an alarm that won't let you start the bike, and random electrical gremlins.... I would suggest the two are related. I'd start by lobbing the alarm in a skip and righting any damage done to the loom by the alarm fitter.
Old 15-09-08, 09:45 PM   #14
joshmac
Default Re: Bang!!
I've started thinking this myself.
Wouldn't really know where to start (as I'm sure you realised when I was trying to restrict my bike ).. I'm guessing take pannels off, follow the wires from the alarm and then, Just remove them?
Would this definitely "re-mobilise" the bike?
Old 15-09-08, 09:48 PM   #15
Default Re: Bang!!
Basically alarm cuts into several circuits and puts itself there as an extra switch.
To do it right you need to be able to solder, and follow wiring diagram. It's a bit of a pain of a job (ask melody about that one before NW3 hehehehe)
Old 19-11-08, 06:31 PM   #16
joshmac
Default Re: Bang!!
Thought it'd be better to dig up this thread than start a new one...
You need to find out where as it may be a chaffing wire. It could short out again or may even cut right through the wire when your miles away from home.
Don't leave it to chance Josh, have a dig around and find the offending connection or wire!
Regards
I'm afraid to say that you were correct (not that I doubted that at the time)
Riding back from Soho on Friday the backfiring/revs dropping/ cutting out have started again.
When I had the bike in pieces before I checked all the wires the best I could, but couldn't find the suspect.
Could it be the sidestand switch causing these erratic backfires? If so how would I check this?
Old 19-11-08, 07:59 PM   #17
BBadger
Default Re: Bang!!
Wondered where you got to on the A3.
If you think its the side stand, find the contract and follow the wires around to see any breaks or lose bits.
If your still having troubles give Riverside motorcycles a call and ask over the phone, that could give you a better idea, or i can pop in an ask some time this week if you want ??
Old 20-11-08, 11:21 AM   #18
vzzzbuxt
Default Re: Bang!!
silly but sidestand switch? is the sidestand loose and when you hit a dip it moves and loosens off the sidestand switch causing the engine to temp stop as thinking sidestand down, then as comes back up engine fires up and ignites the unburnt fuel-bang-
had a similiar prob years back with a gsx400- new sidestand spring cured it
Old 20-11-08, 12:23 PM   #19
joshmac
Default Re: Bang!!
Will have a look when I get home. I hope it's that simple
Old 20-11-08, 12:35 PM   #20
Default Re: Bang!!
Just bypass the switch
chitty chitty fecking bang bang hovis Idle Banter 35 03-01-09 12:33 PM
Bang! jumjum_0214 Bikes - Talk & Issues 25 23-07-08 08:19 PM
Bang! kwak zzr Idle Banter 9 05-11-07 11:03 PM
bang!!!! sv650nutter149 SV Talk, Tuning & Tweaking 18 15-08-07 07:14 PM
kill bill soundtrack bang bang hovis Idle Banter 8 22-05-07 03:53 PM
