Old 16-09-08, 04:00 AM   #11
MiniMatt
Default Re: fuelling up
Originally Posted by mackrilld View Post
i dont sit on my bike when i fill it up will that make a diffrence and soz for being a lil off topic do i need my bike run up on a dyno with the k&n + the zorst
Filling up while sat on it allows you to keep the bike (and hence the tank) more vertical and as such allows you to squeeze a bit more into the tank; not a whole lot of difference tho. I've noticed petrol stations occasionally think you're about to do a runner if you do this though.
As for resetup with k&n and exhaust, assuming you're talking just a replacement drop in air filter into an unmodified air box and a slip on end can rather than a full system, my hunch would be that no new setup is required.
Old 16-09-08, 03:36 PM   #12
lazymanc
Hmm, I'm only getting about 100-110 before the light, but that's mostly commuter miles into and out of town, never getting above about 40mph. I'm a bit of a wimp and haven't ever let it run dry so I dunno how much i'd actually get out of a full tank.
lazymanc is offline   Reply With Quote
Old 16-09-08, 03:47 PM   #13
Smoggy
You've just got to raise the nozzle a bit at first, and then as it gets towards the top, raise it some more and don't squeeze as hard to stop it tripping the back pressure on the pump.
Wouldn't sit on it and bim it by the way.. It'll just go down the overflow as you turn/lean.
Old 16-09-08, 03:53 PM   #14
neio79
On the Kwak i can get 155 till fuel light if i am taking it easy with my Daughter as pillion. so that is probably about a good 177-180 till dry maybe more.
Even when riding a bit more briskly i can get 140-150 till bone dry.
Old 16-09-08, 04:54 PM   #15
Nicky S
Nicky S's Avatar
i get that 2
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 16-09-08, 05:07 PM   #16
stanie
well, on the way back from work today, fuel light flashed, so i pulled in to the next petrol station, which luckily was about a mile away. i put in £14 worth, and that filled it. also, i had the nozzle in to the left side of the tank (i was still sat on it) and it seemed to fill much better than the other day.
so, next question, how much fuel is there when the light first starts flashing?
i need to work out how to set my trip first, then i will see what im getting to my tank.
at the moment, im gunning it, kind of un-intentionally, as i dont realise how fast im going. im still unsure as to whether the speedo is reading correctly. is it likely to be out?
Old 16-09-08, 05:29 PM   #17
BBadger
i just got 150 and that included my blast to brighton and back on sunday.
But the light came on and went off depending if i was on a hill.
just set your trip B to 0 every time you fill up, and then use A for what every you want.
good point how much is left when the light comes on solid, and how much when it flashes??
SV fuelling, air filters etc. metalmonkey SV Talk, Tuning & Tweaking 17 27-10-08 04:22 PM
Fuelling upgrade? gazza SV Talk, Tuning & Tweaking 1 09-05-08 07:21 AM
Sorting out the fuelling. the_lone_wolf SV Talk, Tuning & Tweaking 9 13-08-07 11:18 AM
Engine/Fuelling Problems? curium SV Talk, Tuning & Tweaking 2 09-07-06 01:39 PM
Fuelling Problems curium SV Talk, Tuning & Tweaking 2 15-06-06 02:15 PM
