Old 18-09-08, 05:35 PM   #11
jimmy-james
Default Re: Curvy clutch
Ok! What is the definitive adjustment rule then because obviously i'm stupid!
Old 18-09-08, 10:25 PM   #12
Originally Posted by Sid Squid:
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Old 19-09-08, 07:38 AM   #13
jimmy-james
Thanks Northwind, i will have a go at that today.
Old 19-09-08, 09:58 AM   #14
shifter
does anyone want the spare clutch then?
Old 19-09-08, 05:25 PM   #15
jimmy-james
Not now mate, sorry. The adjustment instructions Northwind posted seen to have done the trick. Thanks anyway and thanks Northwind and Sid Squid!
Old 20-09-08, 09:04 AM   #16
shifter
Foo?
Old 20-09-08, 09:14 AM   #17
jimmy-james
Stick it in the parts for sale bit mate, you might get more joy there.
Old 20-09-08, 10:25 AM   #18
shifter
It can sit on the spares shelf then I reckon
Pointy clutch in a curvy? Jay12329 SV Talk, Tuning & Tweaking 1 10-02-09 12:40 PM
Clutch cover 01 Curvy jumjum_0214 Stuff Wanted 9 10-10-08 05:08 PM
Curvy Clutch basket Grinch Stuff Wanted 5 30-09-08 02:02 PM
Clutch Cable for curvy kciN Stuff Wanted 0 06-08-06 08:32 PM
Curvy clutch lever suicidesam SV Ecosse 5 24-07-06 06:07 PM
