Old 22-09-08, 02:29 PM   #11
Flamin_Squirrel
Default Re: hel brake lines, pics and advice?
Suggest you may have more success filling the resevior and using the syringe to suck fluid through from the top.
another tip is to cable tie your front brake lever to the bar so as its pulled in, that way the cylinder is 'open' to let fluid threw.
*slaps Bibio*
Pulling the lever back shuts off the path through the master cylinder rather than opening it, so don't do that.
Old 22-09-08, 02:52 PM   #12
maff
ok progress so far.....
after the pipe coming off the syring and spraying me and he garage floor in brake fluid,told you im not the brightest hehe
iv taken the cable tie off the brake and i have fluid IN the master cylinder but only a little bit at the mo so ive stopped.
if i do the same on the other side till the bubbles dissappear i should know the both lines are full of fluid yes?
and then just top up master cylinder....hopefully anyway
maff
Old 22-09-08, 02:55 PM   #13
maff
btw the bike is stripped to beyond naked as im cleaning it this week ready for the winter, might be the only chance i get, so not much for brake fluid to get on to
Old 22-09-08, 02:57 PM   #14
Flamin_Squirrel
Are you filling from the bottom? If so you'll struggle to know when all the bubbles are out - they may be on one side but not the other. The reservior will have filled to the brim before that, so you'll have to drain some of it.
Old 22-09-08, 03:01 PM   #15
maff
yes filling from the bottom
maff
Old 22-09-08, 03:04 PM   #16
Flamin_Squirrel
Ok. Think you'll have to just do up the bleed nipples periodically, and squeeze the brake lever. If it's spongey, you've still got air in it.
Old 22-09-08, 03:23 PM   #17
maff
ok, both lines are full, master cylinder is full and the top is screwed back on but i have no brakes! you can pull the lever in all the way to the bar and nothing happens...any ideas?
maff
Old 22-09-08, 03:26 PM   #18
Flamin_Squirrel
You've still got air in the lines.
I'd suck fluid out from the calipers if I were you. Remember to top up the reservior as you go - if you don't you can let more air in at the top and you'll have to start again.
Old 22-09-08, 04:22 PM   #19
*slaps Bibio*
ok slap me, i'll be your bitch
so why does air come out of the system when you cabletie your brake lever overnight?
Old 22-09-08, 04:27 PM   #20
maff
iv tried sucking it out from the bottom and as much brake fluid is coming out im getting the same amount of air bubbles. either im opening the nipple to far or iv knackered something
the brake lever feels better but not what i know it can be so ive given up for now. ive zip tied the brake lever to see if that will do anything over night if not then im stumped
maff
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Advice please! brake lines. BBadger Hardware 7 25-10-08 12:00 PM
Brake LInes vardypeeps SV Talk, Tuning & Tweaking 6 02-10-08 04:38 PM
HEL Brake Lines buckstone SV Talk, Tuning & Tweaking 1 20-05-08 04:24 AM
HEL brake lines streetos SV Talk, Tuning & Tweaking 4 31-03-05 09:51 PM
