#11 |
hmm could be many things but are you sure its threading right? It shoudlnt be ****ing oil even if its not sealing well. Just a drip.
On a similar note does anyone know the oring size for the clutch cover? |
#12 | |
However I've noticed that when I removed one of the engine bolts to take off the belly pan the bolt was wet with oil and there was actually a damp greasy patches down the engine casing from there soperhaps it's running down to the bottom and dripping off the sump bolt? Is this normal??
#13 |
I hope someone can answer that before it goes dark! ^
Stop me draining my oil pointlessly
#14 | |
The clutch cover is a common leaking point on the Curvy's and it is the reason why the later ones and Pointy's had the one piece clutch cover. |
#15 | |
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
#16 |
Also the tip from Dave is a good one, with dgreaser. My other half also suggested to me to put some talc on it afterwards, before you go for a ride, sounds daft but, you would get a clear marker on the talc where the drip ran down. i haven't got round to it yet
#17 | |
Won't drop the oil again just yet til' I've tried it
#18 |
Well just started it up with that bolt out and it was spluttering a fair bit of oil out of the hole. I've noticed that someone's put a washer on this engine bolt at some point - probably the mong I bought it off (wondered why I managed to haggle him £300 off
![]() ![]() Anyhow not a happy bunny ![]()
#19 |
Put a fibre washer on said bolt...hopefully that'll hold tight
#20 |
grr it's leaking at the heads now. Lost about 300ml yesterday/lastnight. I've been advised to torque up the head bolts and if tht doesn;t sort it a new gasket set.
wooptydoo
New to SV's | seanoconnor | SV Talk, Tuning & Tweaking | 11 | 05-03-09 05:29 PM |
How many SV's are actually on here then? | Brettus | Bikes - Talk & Issues | 26 | 10-01-08 10:59 PM |
How do you stop dogs peeing on your bike? | Davies | Idle Banter | 23 | 19-03-07 07:12 PM |
How many SV's!!! | krhall | Bikes - Talk & Issues | 29 | 18-12-06 04:44 PM |
k5 and k6 red sv's? | kwak zzr | Photos | 7 | 06-08-06 09:28 AM |
