Old 29-09-08, 01:49 PM   #11
Spiderman
Where the hell am I?
Spiderman's Avatar
Default Re: One problem to anothe - No spark
i know its a silly question but do any lights come on when you turn ignition key? Could just be a flat battery if no lights.
Old 29-09-08, 03:12 PM   #12
ThEGr33k
The starter motor turns over the engine so no not that...
Any luck last night Josh?
Old 29-09-08, 09:05 PM   #13
joshmac
Nope.. Managed to get the tank off tonight (at last!!), and have a multimeter at hand, so I'm going to take a few readings..
Longshot, especially with me in control
Old 29-09-08, 10:07 PM   #14
phil24_7
No better way to learn about your bike than to find, solve and fix problems!
Old 29-09-08, 11:29 PM   #15
metalmonkey
How did you get the tank off in the end? Was that connetctor just corded as we talk about?
It will be so much easier to work on the bike now. Can I suggest that you write down everything that you have done, and checked and what connects to where and what. If your anything like me, my memory isn't great.
Then you now where you are at and should it go tits up again you own record what you have done to the bike. I will be doing that for all my bikes, I mean will you really remeber what you did in detail a year on from now? I won't so write it down!
Other than work through each part and system one bit at a time, I'm not free for a few w/ends now
Old 13-10-08, 09:32 PM   #16
joshmac
Just thought I'd post an update.. Bike is working again, I think it must have been a loose connection, but I couldn't find where ...
Old 14-10-08, 06:35 PM   #17
phil24_7
You need to find out where as it may be a chaffing wire. It could short out again or may even cut right through the wire when your miles away from home.
Don't leave it to chance Josh, have a dig around and find the offending connection or wire!
Regards
Old 14-10-08, 10:40 PM   #18
joshmac
Regards
I did have a look for about half an hour when the tank and fairings were off, but couldn't find anything
Old 15-10-08, 08:59 AM   #19
chrisc
Kill switch but too embarassed to say?
Old 15-10-08, 10:21 AM   #20
joshmac
No! thankyou very much Bike was turning over but just woudn't fire, so
I wouldn't have a problem with admitting a mistake like that though, as I'm sure everyone's done something similar once in their bike career and it could help someone to fix a 'problem'
Front spark plug problem in the wet and washing kurtis.randle Bikes - Talk & Issues 15 04-04-09 09:16 PM
Spark plug problem! Phaelok Bikes - Talk & Issues 3 11-02-09 10:28 AM
HELP! spark plug problem heedbaw SV Talk, Tuning & Tweaking 7 23-10-07 02:36 PM
No Spark yorkie_chris SV Talk, Tuning & Tweaking 27 15-09-07 05:29 PM
No spark...please help. leegriffiths128 SV Talk, Tuning & Tweaking 0 11-11-05 05:17 PM
