#11 |
do you think changing the plate will fix my problem. the bolt and fork on the stand seem to be fine although i did close the gap in the fork part of the stand which did solve my prblem but today its catching again whihc makes me think tht the bolt maybe gone to. think ill just try one at a time .
thanks for all the help guys. huskey ive pmd you. |
#12 |
If the fault is with the plate only then the stand it self should be good and reusable.
#13 |
The Sick Man
remember that even a 1mm wear in the bolt will work out as a large movement, but if you say that the hole is properly oval then its prooly a good start there, GSXR side stand plates will fit SV curvies
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#14 |
£61.80! Ouch.
Welder.
Could the SV side stand break off | Tomis | Bikes - Talk & Issues | 13 | 02-04-08 12:59 PM |
Side Stand | Giffer2 | SV Talk, Tuning & Tweaking | 3 | 23-06-07 07:38 PM |
Storage: Side stand or rear paddock stand? | Maudster | SV Talk, Tuning & Tweaking | 19 | 20-01-07 04:45 PM |
Moving the SV on the side stand! | suzsv650 | SV Talk, Tuning & Tweaking | 6 | 15-10-06 08:09 PM |
Side stand | Tris | SV Talk, Tuning & Tweaking | 6 | 17-10-04 12:12 AM |
