Old 10-10-08, 11:27 AM   #11
Default Re: late for work and bikes playing up
It will do if you leave it on on a hot engine.
I use the choke (idle enrichment, not a proper choke but hey de ho) for a couple of seconds, turn it off as soon as it will run smoothly.
Old 10-10-08, 11:30 AM   #12
Dangerous Dave
+ 1, don't keep it on when you are riding down the road as you are over fuelling.
I start the bike with choke (if needed) and then put my helmet on and remove the choke.
Old 10-10-08, 11:51 AM   #13
AndyBrad
oh right
i awways saw it as like a fast idle with a bit of extra fuel. Doh. ill get my coat. cheers chaps.
Old 10-10-08, 03:25 PM   #14
captainsmelly
apologies, i'm butting in. very rude, sorry. i've got a similar problem, bike will not idle off choke until it has been run for a few minutes. i always try and only run it choked for the shortest possible time but it spluters, revs drop and it dies. whythatthen?
Old 10-10-08, 03:27 PM   #15
Not exactly unheard of, perhaps your idle is too low or the carbs need balancing
Old 10-10-08, 04:09 PM   #16
Dangerous Dave
+ 1, first two things to look at.
Old 10-10-08, 04:21 PM   #17
captainsmelly
ok. idle's (when warm) at 1400, steady, no hunting. occasional pop from 'zorst. i'll get it sorted next week when somebody's doing a bit of work to it. cheers andybrad for raising the issue, i thought it was normal until now. thank's DD and YC
Old 24-10-08, 10:46 AM   #18
AndyBrad
RIGHT
struggled again this morning. no choke at all. set off and it just had no power. pinned throttle had the bike topping out at 5k revs and the bike struggled. Had a bit of knocking but after about 3 miles it spluttered and then went like the clappers again.
Your thourghts please folks? Im thinking it was wet yesterday so damp front plug?
Old 24-10-08, 10:51 AM   #19
Sounds like it
Old 24-10-08, 11:13 AM   #20
Dangerous Dave
You are thinking in the right way....
Do you have a fender extender fitted to your SV, I can't see one in your Avatar....
Not too late northwind 2008 Annual Rideout 29 03-07-08 10:49 AM
Its a bit late but here they are!! Jester666 Soho Massive 2 15-02-08 10:19 AM
How do computers on bikes/cars work out fuel economy? monkey Bikes - Talk & Issues 12 16-10-07 08:22 AM
Playing with my phone work furrybean Photos 5 17-03-07 10:49 PM
