#11 |
Get some fresh petrol and plugs in it and it should at least run then.
#12 |
One problem at a time, and don't go buying bits until you've made sure they're at fault. That's an expensive way to fix a motorbike.
You've removed the rear plug. If you ground it on an unpainted bolt and turn the bike over on the starter, does it spark? Jambo
#13 |
Have you got a multimeter to check the charging system yet?
#14 |
It's a bit hard to do that if it won't start
#15 |
Quite so,but flat battery was the original issue,and theres no point in keeping buying new batterys if you dont get geared up to find the original problem.
#16 |
Yup, a acquaintance of mine boiled a total of 4 batteries before realisation set in that the reg-rec was blown. It took a CDI getting upset about being fed 50v of AC and frazzling before deciding to check the charging system.
One born every minute...
#17 |
OK, latest update.
I charged the battery up to about 13.1V. I then removed the spark plug, touched against an unpainted bolt and hit the starter. There was nothing at first but after a quick clean I got some nice blue sparks. I put it all back together and hit the starter - hey presto we have life! It's now idling at 4000rpm (choke closed) and won't go any lower unless I squeeze the throttle further in the closed position. It then goes down to 3k idle but jumps back to 4k as soon as I release the throttle. I ran the bike for a short run but it wasn't safe to drive due to the high idle. When I tried to adjust the throttle play the machine jumped to ~9k and wouldn't come back down. The bike starts OK for now but is just screaming away. Next stop is to lube/adjust the throttle cable or maybe even replace it. Cheers for the support with regards to the battery! You've taken a lot of stress off me. |
#18 |
Not sure whether this applies to the SV - but while your oiling the throttle cable prob be worth checking the cables aren't snagged anywhere.
Disclaimer: - could be talking rubbish |
#19 |
There appears to be 2 throttle cables on my bike. I read elsewhere that this is one cable to open the throttle butterflies and another to close them. Should these both be adjusted to the exact same degree?
#20 |
Yes there are 2 cables. It's a push-pull, so one cable opens throttle the other closes it. Get the tank up and have a look at the throttle cam, see if it is closing all the way against the stop when you shut the throttle manually.
Optimate battery charger drains the battery | flymo | Bikes - Talk & Issues | 10 | 10-06-09 10:41 AM |
Duff printer cartridge? | missyburd | Idle Banter | 10 | 09-05-09 02:09 PM |
What battery? | richie95 | Bikes - Talk & Issues | 11 | 15-06-08 08:35 AM |
Which new battery? | independentphoto | SV Talk, Tuning & Tweaking | 2 | 19-07-06 02:36 PM |
Battery/Starting problem - new battery hasnt fixed it! | Aaron | SV Talk, Tuning & Tweaking | 13 | 24-01-05 05:21 PM |
