View Poll Results: Which shock should I go with
You've got a k5 gsxr thou shock, it won't be perfect but will be good enough 7 36.84%
You're quite heavy so you'll feel the benefit by fitting a stiffer (kwak) shock... 1 5.26%
Whatever yorkie chris suggests is the best choice... 11 57.89%
Voters: 19. You may not vote on this poll
Old 21-10-08, 11:25 AM   #11
Grinch
Default Re: the shocking truth about shock absorbers... (noob questions as asked by myself)
Tell you what... give them to me and keep the original... solves the problem.
Old 21-10-08, 11:46 AM   #12
Luckypants
Luckypants's Avatar
Can I change my vote? Looking at the table, the GXSR1000 shock will be an improvement for you in terms of spring stiffness.
Old 21-10-08, 11:49 AM   #13
Paul the 6th
Paul the 6th's Avatar
where did you get that table from mr pants?
I'm guessing the 330mm length on the pointy sv shock is the reason why the battery box needs hacking when a 332.5mm gsxr shock is fitted? Because of the 2.5mm?! <mr. t> that don't make no sense fool! </mr. t>
pointy sv 430 vs kwak ninja 540 strength (is that in kg/mm?)
thanks for all your patience so far everyone, I am crap
Old 21-10-08, 11:53 AM   #14
plowsie
No KeithD option in Poll - Start again!
I'd say thou will be fine for you Paul.
Old 21-10-08, 11:57 AM   #15
You need to cut the battery box because the reservoir on the GSXR shock needs to live somewhere. SV shock is emulsion type, oil and gas just sloshes about.
IMO the k5 gsxr thou shock will be a slight improvement in spring rate and a massive improvement in damping. Too hard a spring is not always good if you can use enough preload to get sag right on a softer spring.
Old 21-10-08, 12:02 PM   #16
P.s I don't know much about pointies...
I reckon the gixxer one will work, which option should I vote on?!?!?
Old 21-10-08, 12:03 PM   #17
Stu
Trinity
Stu's Avatar
Somewhere on the forum I guess
No, it needs hacking to make room for the separate reservoir that the stock one doesn't have.
Oh well beaten to it
Old 21-10-08, 12:05 PM   #18
Paul the 6th
i suppose I'm not a maniac on the roads either, I just want to tidy up the shock and front end. If I was looking to shave seconds off my commute time to the track and practice sessions then maybe I should be a bit more concerned about this kind of thing, but seeing as though I just want to improve the feel/damping, and plenty of others have done it & are happy with it, I guess the gsxr shock will be fine for my requirements.
case closed. Now then which bathroom should I go for?
Last edited by admin; 18-09-13 at 04:53 PM. Reason: link removed at request of vistoria plumb IT
Old 21-10-08, 12:06 PM   #19
Luckypants
Luckypants's Avatar
That has been posted in just about every shock swap thread on the org! I just swiped it from the latest incarnation which has some updates from Blue_SV650S.
What Y-C says is good stuff. I got a ZX10 shock for my curvy, but thought I might have been better with a stiffer 'Busa shock. Wound on pre-load to get the sag right and it was lovely, compliant and well damped. I think having good damping is what makes the biggest difference to the ride / handling.
Old 21-10-08, 12:07 PM   #20
Paul the 6th
top stuff matey, thanks for you help.
maybe we could do with contributing to and/or tidying up the faq's and how to section on the main site. It would save searching through the endless threads for the same tables and info. Which shock will fit which bike, whats the spring rate etc?
Many noob questions need answering? AndyL Bikes - Talk & Issues 29 08-08-08 06:27 PM
Noob with stupid questions MeatSwinger SV Talk, Tuning & Tweaking 1 03-02-08 11:47 AM
Ohlins shock questions? svrash Bikes - Talk & Issues 21 17-10-06 09:54 AM
Questions asked over terror raid...... akbarhussain Idle Banter 161 13-06-06 07:31 PM
Noob Questions jeremysilver75 SV Talk, Tuning & Tweaking 11 01-06-05 03:45 PM
