Old 27-10-08, 12:01 PM   #11
Sean_C
Default Re: 110v American Extension Leads
Might be worth going down there and asking one of their knowledgeable employees?
Old 27-10-08, 12:02 PM   #12
gettin2dizzy
Well i bought one that included a step down transformer. Are you wanting just the extension lead itself?
Old 27-10-08, 12:02 PM   #13
Mr Speirs
Mr Speirs's Avatar
Yup
Old 27-10-08, 02:03 PM   #14
mister c
mister c's Avatar
If it is definitely 110v why dont you just change the plug to one of the Yellow 16a eu standard ones then use a std extension lead
Old 27-10-08, 02:11 PM   #15
Mr Speirs
Mr Speirs's Avatar
I need to be able to plug american appliances into the extensions. Its okay now I've managed to come up with a solution.
Old 27-10-08, 06:00 PM   #16
MrMessy
I work with Americans and if I remember rightly British yellow transformers are centre tapped and not the same as the transformers we use to go from 240 to 110V. You will need a few transformers and leads for the power a band use? Have you checked if their equipment is dual voltage? Can they bring leads across with them? You may need to find a local American Base and see if you can borrow some equipment from them!
MrMessy is offline   Reply With Quote
Old 27-10-08, 06:22 PM   #17
robbills
I could get you what you need if you post a pic of it.
Rob
american sv. Gene genie Photos 40 29-05-09 05:44 AM
autocom leads theshed SV Talk, Tuning & Tweaking 5 01-02-09 04:53 PM
Wiring phone extension - HEEEEELP 600+ Idle Banter 12 24-02-08 02:44 PM
Playstation2 Leads... Richie Idle Banter 1 31-10-07 05:32 PM
HT leads svrash SV Talk, Tuning & Tweaking 2 31-12-05 10:44 PM
