Old 08-11-08, 02:12 PM   #11
Baph
Default Re: help! Computer installation
In that case, I'd personally be tempted to stick a normal SATA drive in & sort the raid out later, but that's just me.
If you don't have any kicking around, then you'll still want the same drivers (I think the D9150's use Intel Matrix anyhow), but it might be safer to disable AHCI & revert back to ATA mode just for the installation.
Old 08-11-08, 02:29 PM   #12
Caddy2000
by that, do you mean take one of the drives out and carry out the install with one drive?
Old 08-11-08, 02:31 PM   #13
Baph
I was meaning to connect a spare drive & put that in the case permanently, something small, just enough to hold the installation of XP really.
You could take one of the RAID drives out & carry on with the installation (connecting the drive to the normal SATA controller, not the RAID, or disabling RAID), but then converting it back to RAID later could be a royal pain.
If you don't have a spare SATA drive, pop down to the library as I said above.
Old 08-11-08, 02:44 PM   #14
Caddy2000
Cheers Baph,
I've dowloaded the Matrix driver from Dell, and will change to ATA to see if that makes a difference.
Why oh why didn't I get an Apple!!!
Old 08-11-08, 04:10 PM   #15
or a usb floppy drive...
if you are really interested i can help you create an unattended installation disc. but it would require you to have a working windows machine.
it loads drivers, apps, os and keys all at the same time .. no user interaction .. just chuck the disk in and press return.
have a look here to see what's involved.
http://unattended.msfn.org/unattended.xp/
Old 08-11-08, 04:12 PM   #16
Baph
That's what I was saying about the Nokia N95 acting as a Mass Storage Device.
Old 08-11-08, 04:21 PM   #17
yup .. bit more complicated as in.. you would have to point the os to the drive/folder/driver... but sometimes it wont install properly.
Old 08-11-08, 04:40 PM   #18
Caddy2000
annoyed now! No matter what i do, it won't see the hard drives
Old 08-11-08, 04:45 PM   #19
thats because the drivers arent loaded.. or your drive has collapsed..
are you using a windows disc or a re-installation disc supplied by the manufacturer?
Old 08-11-08, 04:49 PM   #20
Baph
Also, in BIOS, what are your SATA settings? You should be on "Combination" not "Raid Autodetect/AHCI". I know that's a tad contradictory to what I wrote above.
Alternatively to this, I'm told the drivers are native on the SP2 version of XP.
New M4 slip on installation. Chet SV Talk, Tuning & Tweaking 7 17-05-08 10:03 PM
new fairing installation kidpuffy SV Talk, Tuning & Tweaking 0 19-04-07 10:57 PM
Alarm Installation - HELP ugp Bikes - Talk & Issues 6 08-08-06 08:36 PM
New Jet Kit installation? DoctorJ SV Talk, Tuning & Tweaking 6 02-05-05 07:31 PM
Datalogger installation pillion_soon to be rider SV Talk, Tuning & Tweaking 1 02-01-70 05:30 PM
