Old 11-11-08, 02:00 PM   #11
boo86
Default Re: Glowing downpipe
Originally Posted by MrTom View Post
Just run my bike for a few minutes to keep it ticking over every now and again through the winter.
It was running for about 3 minutes with a good dose of choke and when I came to switch it off the downpipe was glowing, I mean really GLOWING!!
When I did switch it off it let out a load bang with accompanying fireworks show from the exhaust.
So what do you think the problem is?
Putting my optimistic hat on I'd say that the engine turning at above idle speed (choke on) without cooling airflow is bound to warm the pipe a little, and the backfire was just coincidentle, or caused by a little unburned fuel ingniting in the hot pipe.
Or, could an exhause valve been not completely closing, exposing the exhaust to the combustion.
Mine glows too. I only noticed after the dark nights came in and I was in my shed. I've got a multi meter with a temperature gauge which I used on the pipes. All seemed in order. I wouldn't worry about it. Mine's a race bike and I've got it ideling at 2500 rpm so that'll be about the same as yours on the choke I think.
Old 11-11-08, 02:21 PM   #12
Why idling at 2500rpm?
Old 11-11-08, 02:46 PM   #13
boo86
I'd love to give you a technical reason but truth is I just prefer it that way. I've got drilled slide holes and the on / off throttle response is truly horrific. I play with idel speed to try and reduce it. It's handy round slow corner. It's not so bad now I have stiff suspension but when I had a standard front and rear susp when I put some beans on the front was up and down like a yo-yo.
Old 11-11-08, 05:45 PM   #14
Interceptor
The glowing front pipe happened to me once while I was testing the radiator fan sensing switch, left it idling for too long with no airflow in the garage....
They all do that sir...!
Old 11-11-08, 06:15 PM   #15
Nothing wrong with setting things up how you like, but drilled slides shouldn't do that... Unless maybe they're SERIOUSLY drilled Wonder what's causing it
Old 11-11-08, 09:19 PM   #16
High idle kills the engine braking though. Are they balanced and what's the mixture like at tickover?
Old 12-11-08, 02:06 PM   #17
Blue_SV650S
Are the pipes titanium? I am surprised stock ones heated that quickly ... the thin titanium ones glow a gooden in no time mind
Old 12-11-08, 02:17 PM   #18
Alpinestarhero
When Chris Walker raced the then National Tyres Crescent Suzuki GSXR750 in BSB, they ran a very high idle speed (3000 rpm I recall?). Apparently it helped stop the bike unwantedly backing into corners off the throttle
Old 12-11-08, 02:24 PM   #19
Blue_SV650S
Its a standard thing to do .... it is not just walker!!
Old 12-11-08, 02:31 PM   #20
Alpinestarhero
Yea, i realise that - at brands hatch you can hear the race bikes going from the paddock to the pits idling quite high.
Do you run a higher tick-over on your trackbike? I do notice on my bike when I pull away in the mornings and the bike is not warm (idles at 1100 rpm), the engine braking is harsher than when its warmed up (idles at a tade below 1500 rpm).
Crash.NET - PIC: Rossi glowing in the dark. NewsBot News 0 17-04-09 11:30 AM
Polishing the downpipe? GC-SV SV Talk, Tuning & Tweaking 17 06-03-06 09:55 PM
exhaust downpipe hutchy SV Talk, Tuning & Tweaking 10 19-01-06 03:04 PM
Front downpipe TSM SV Talk, Tuning & Tweaking 7 13-03-05 12:33 PM
eye ball silver K4 on A40 with glowing red exhaust kjames Bikes - Talk & Issues 2 05-03-05 10:48 PM
