Old 16-11-08, 11:25 PM   #11
arcdef
Default Re: this is probably the most obvious question ever but.....
pads will rest on the disks and you will hear them when pushing the bike around.
Oh so i should be able to hear something? Thats ok then i will mention it and see what they say though!
Old 17-11-08, 12:03 AM   #12
You will usually be able to hear pads even if they're not siezed
Test I do is to spin the wheel with it off the ground, significant resistance is not good.
Old 17-11-08, 01:36 PM   #13
vardypeeps
Default Re: How can I tell if my brakes are seized?
Yeah I was just about to say that I serviced my brakes recent but the bike has been sat for a week due to the chain snapping and a little rust has built up on the discs which when I move the bike makes the noise above. After checking my wheel for resistance like chris said above all seems fine they just need a little clean and a good run out on the road to get em working tip top.
Old 17-11-08, 01:39 PM   #14
Stig
If they are seized you will either not be able to stop or not be able to go.
Hope that helps.
Old 17-11-08, 01:40 PM   #15
Or maybe you'll be able to do both but it'll knacker the discs.
Old 17-11-08, 02:28 PM   #16
arcdef
well in the small space i moved it both front and rear brakes worked with the smallest use so they do work and i can move but will pay more attention next time i go view it
quick OT question but is there and storage space under the pillion seat? i know there is in the pointy version but what about the round one?
cheers guys
Old 17-11-08, 02:31 PM   #17
Yes there is
brakes seized......... a bit hovis Bikes - Talk & Issues 7 25-01-08 08:05 AM
seized bolt + more hovis Bikes - Talk & Issues 26 07-01-08 11:06 PM
Seized caliper OldBoy SV Talk, Tuning & Tweaking 6 31-03-07 11:51 AM
Think i've seized it :-( Daimo SV Talk, Tuning & Tweaking 22 22-07-06 06:34 PM
Seized brakes!!! Hogzi SV Talk, Tuning & Tweaking 4 24-02-06 08:37 PM
