View Poll Results: Which uses more fuel?
Engine braking 7 41.18%
clutch in and use brakes 10 58.82%
Voters: 17. You may not vote on this poll
Old 17-11-08, 01:19 PM   #11
jimmy__riddle
Default Re: Which uses less fuel?
some mixed answers!
I should add its not about me penny pinching, not fussed about that at all. i was just wondering from a engineering/science point of view.
Old 17-11-08, 01:21 PM   #12
The answer is a massive "it depends"
Old 17-11-08, 01:24 PM   #13
jimmy__riddle
yeah i thought it might, the vehicles we were originally talking about were a 2.5TD L200 and a 2.2 petrol (carbed) Hilux.
Old 17-11-08, 01:27 PM   #14
Well a standard (not common rail) diesel has fuel flow proportional to engine speed and throttle position. So not much difference.
Old 17-11-08, 02:02 PM   #15
startrek.steve
Originally Posted by jambo View Post
If all else fails, fit a Sid Squid, annoyingly this makes more difference to fuel economy than anything else I've tried.
Jambo
Whats a sid squid?
Old 17-11-08, 02:03 PM   #16
Who's got that .gif of him with the lightbulb on his head?!?
Old 17-11-08, 02:04 PM   #17
Biker Biggles
Biker Biggles's Avatar
Its a sort of automatic pilot that drives your vehicle around without using any fuel.
We should market it really.
Old 17-11-08, 02:08 PM   #18
Daimo
As said, when an engine is idling, its still using a lot of fuel to turn the engine over.
When using engine braking, the momentum is still turning the engine and not forcing any fuel in.
Our VXR does 0.2mpg when on idle, but you leave it in 6th and slow down it'll ratain max of 999.99 (therotically, no fuel used at all).
Old 17-11-08, 02:14 PM   #19
breakz187
I thought that the engine braking causes the vacumn to build up massively, reducing the amount of pressure within the fuel pressure regulator. I thought this was how it worked on injected petrol engines anyway. Obviously the injectors will have different control logic but i dunno...
Old 17-11-08, 02:16 PM   #20
Depends if it's a 2port reg or 3port ... compensated or not... (obv a 3port won't be compensated...) Basically ECU logic can cut fuel flow entirely on the overrun if programmed to do that.
Fuel @ the NEC Bassman SV Talk, Tuning & Tweaking 4 19-11-07 12:24 PM
Not Fuel, so who else is there? Berlin Exhausts 7 05-09-07 04:11 PM
Replacement fuel light / fuel tap riktherider SV Talk, Tuning & Tweaking 7 14-05-07 06:41 PM
Dry fuel BURNER SV Talk, Tuning & Tweaking 8 18-11-05 05:09 PM
Fuel cap? Bikerz SV Talk, Tuning & Tweaking 3 06-06-05 08:46 PM
