Old 28-04-10, 12:04 AM   #11
Nicky S
Nicky S's Avatar
Default Re: renthal streetfighter bars on a naked sv
ok my pointy i loosened off the wiring holder things and pulled some more wire through, cables are all fine, and got some custom length brake lines made, and re routed the throttle cable's
and who ever sead they are to wide is talking cobblers in my opinion , if you think the renthals are wide you should try some MT-03 handle bars they are huge
lol
how much did your custom brake lines cost ? atm i have goodridge race lines on my bike but they seem a bit tight at the master cyclinder but the more i think about it i think i might have put one on upside down.
how did you reroute your throttle cables did you still go through the middel of the forks ?
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 28-04-10, 12:08 AM   #12
barwel1992
cobra brake line they are hel lines and banjos but made by a bloke and his wife on ebay, only £40 for fronts any size you want ohh and they are very good quality
and throttle cables were routed back through the frame and then through the opposite side of the frame giving about 3-5cm more play
Old 28-04-10, 12:17 AM   #13
Nicky S
Nicky S's Avatar
kk cheers mate i will have a look 2moz
Old 28-04-10, 12:20 AM   #14
barwel1992
you can see the slack in this pic
excuse the damage
Old 28-04-10, 12:31 AM   #15
Nicky S
Nicky S's Avatar
are these the brake lines http://cgi.ebay.co.uk/SUZUKI-SV650-X...item439e987ed4 ?
if so it dose not say anything about them being custom or longer ???
Old 28-04-10, 12:52 AM   #16
Geodude
Geodude's Avatar
Originally Posted by Nicky S View Post
hey guys i have added some renthal ultra low bars to my curvy and im having some problems.
all leads and lines are very tight
when i ride along then stop the bike revs at around 4k is this becuase the throttle cabels are being streched or is it becuase of the choke ..... im thinking choke and left switch plastic bit
also the leads rub on the indy brackets ... so my plan to fix that part is to drill 2 holes in the silver metal bits that hold the light on and stick them there and cut off the metal bracket that are on the forks.
has anyone elsa had this problem? how did you fix it?
and if worse comes to worse then im going to cut the bars down a bit
I have same bars and just took off 20mm from each side, sorted it.
Old 28-04-10, 12:55 AM   #17
Nicky S
Nicky S's Avatar
kk so buy cutting 20mm off each side the lines no longer rub and you have had no problems with it over reving ?
Old 28-04-10, 12:59 AM   #18
Geodude
Geodude's Avatar
I have a little rubbing but no over revving or stretching, but before i did the tweak when i turned right the choke would pull on.
Old 28-04-10, 01:15 AM   #19
Nicky S
Nicky S's Avatar
same problem i have now cheers for the help mate
Old 28-04-10, 10:14 AM   #20
barwel1992
those are the lines, just send them a message and ask if they would add 5-10cm's on she will say yes then order them and put how much longer you want the lines in the comment box when you pay
Renthal Bars - Some Questions xlewdx SV Talk, Tuning & Tweaking 14 26-07-09 11:07 PM
Renthal Bars sv_to_gsxr SV Talk, Tuning & Tweaking 7 19-06-08 09:08 AM
Renthal Streetfighter bars tomjones2 Bikes - Talk & Issues 2 18-09-07 06:57 PM
Renthal Bars 21QUEST For Sale - SV's and SV related items 1 06-04-06 09:10 AM
Renthal Bars for SV 650 Chris V SV Talk, Tuning & Tweaking 16 01-09-05 05:37 PM
