#11 | |
http://www.smartsynthetics.com/artic...ical_facts.htm An excerpt taken from it: "It is important to note that as an oil classification is superseded by a newer one, that the newer one provides improved benefits over the older one in such areas as high and low temperature deposits, wear, rust and corrosion for example and is perfectly suitable for use. All quality motorcycle specific oils should also carry the JASO Motorcycle Specifications, which are either the JASO-MA specification (no friction modifiers) or the JASO-MB specification (with friction modifiers). The JASO-MA rating specifies that no friction modifiers are used. Note that the JASO-MB motorcycle does have friction modifiers, but is designed for motorcycles thatspecify theJASO-MB specification.If the oil does not carry one of these specifications, even if the other specifications listed above are present, We recommend finding an oil that has the proper JASO specification clearly labeled on the bottle." |
#12 |
As for the gearbox issue, bike oils have typically 50% more phosphorus content than "modern" car oils (measure of the ZDDP additive used to protect against wear in extreme pressure contacts like transmission gear teeth and traditionally for valve train cam/tappet wear).
The phosphorus degrades exhaust catalysts, and car manufacturers have to demonstrate compliance with emission performance (regulated pollutants) at very high mileages so catalyst deterioration is a big issue. Oil companies have been reducing ZDDP in car oils progressively over the years.
#13 |
#14 | |
AR08 to AR13-QUALITY! 650s: '52 curvy in yellow, was my baby ![]() cbr600rr: Mivv exhaust and a bagster tank cover. Now gone to a new home. Daytona 675: Arrow can (with a baffle that's gone missing in action.... ![]() ![]() |
#15 | |
#16 |
Ignore the SF/SG spec recommended and look for JASO MA on the container. JASO is the Japanese body who set the standards for oils, and as you'll be putting it in a Japanese bike, go with what the little slanty-eyed man in the white lab coat recommends
#17 | |
not helpful, lol
AR08 to AR13-QUALITY! 650s: '52 curvy in yellow, was my baby ![]() cbr600rr: Mivv exhaust and a bagster tank cover. Now gone to a new home. Daytona 675: Arrow can (with a baffle that's gone missing in action.... ![]() ![]() Last edited by chris8886; 08-12-08 at 10:35 PM. Reason: spelling |
whats the differance? | Richie | Idle Banter | 13 | 20-02-08 05:04 PM |
Is there a differance.... | skapegoat | Bikes - Talk & Issues | 5 | 06-02-08 07:51 PM |
spot the differance | hovis | Idle Banter | 10 | 20-11-07 02:01 PM |
Sharman Multicom Bike to Bike radios, complete, NOW SOLD | jakeblues68 | For Sale - SV's and SV related items | 4 | 24-04-06 09:35 PM |
Does A bigger back wheel/tire make a Differance? | Frestyl | SV Talk, Tuning & Tweaking | 19 | 29-06-05 06:25 PM |
