Old 10-12-08, 10:19 AM   #11
jambo
jambo's Avatar
Default Re: Winter Maintenance?
I tend to mix some motor oil and LM grease up and use a toothbrush to apply that to all the bolts and fixings I can see. Keeps them from getting too corroded, barely needs re-applying and can be used near brakes as you're not spraying all over the area.
Lube your chain more often, ride frequently.
Jambo
Old 10-12-08, 10:22 AM   #12
Ceri JC
Cleaning an SV used regularly through winter is a waste of time IMO. On bikes with a better finish it may well be worthwhile, but the SV will corrode to some extent regardless of what you do. I'd rather save the money/time on cleaning it to replace parts when they invariably do get ruined.
As others have said, with the amount you're using it, an optimate is probably overkill.
Old 10-12-08, 10:25 AM   #13
Alpinestarhero
Washing things down with water is a good idea, especialy things like the rear shock etc. I don;t use any protectice coating on my bike, but I might look into it.
Be aware that your chain will have loads of crap stick to it, so be sure to clean it with parafin and use a good lubricant after; I use thicker chain lube in the winter...the wurth stuff seems to wash off quicker.
Old 10-12-08, 12:52 PM   #14
ophic
ophic's Avatar
Originally Posted by Ceri JC View Post
Cleaning an SV...
doing what?!
I just write my name in the dirt. That way I don't have to lock it
Silver SV650SK3, Fuel exhaust
Old 10-12-08, 01:05 PM   #15
Grinch
I have a Pyramid hugger I got on e-bay for a tenner, that protects my shock just nice.
Old 10-12-08, 01:31 PM   #16
Viney
I find the crap flap does just as good a job as my old hugger did
Maintenance Bill.Cross SV Talk, Tuning & Tweaking 3 07-03-09 10:02 PM
Winter care and genaral maintenance DaveP Bikes - Talk & Issues 10 03-11-08 02:39 PM
Maintenance? catchsomesv650 SV Talk, Tuning & Tweaking 20 17-08-07 10:58 PM
SV Maintenance Draper Bikes - Talk & Issues 6 21-05-07 10:27 PM
Winter Brake Maintenance curium SV Talk, Tuning & Tweaking 0 17-12-05 03:50 PM
