Old 14-12-08, 05:10 PM   #11
thefallenangel
Default Re: What's up with the ignition?
i had a similar problem with the fuel pump connector.
Old 17-12-08, 10:02 AM   #12
arcdef
only just got the chance to go have a look and after playing around i found that pulling in and releasing the clutch made it start so pretty sure it will be that.... is it the two black and yellow wires i need to cut and rejoin or would i be better off trying to open it up and cean the connection??? if so how do i do that!!
cheers
Old 17-12-08, 10:14 AM   #13
Dangerous Dave
Dodgy clutch switch it seems, just cut and connect the two wires to by pass it.
Old 17-12-08, 11:09 AM   #14
arcdef
the two yellow and black wires??
cheers
Old 17-12-08, 11:15 AM   #15
Dangerous Dave
I can't remember the colour off the top of my head (getting old) but if you are referring to the two wires leading into the black connector which plugs into the underside of clutch lever perch then yes, cut and connect.
K5 SVS No ignition fizzwheel SV Talk, Tuning & Tweaking 26 21-12-07 02:42 AM
ignition sv 650 suzanne2869 Stuff Wanted 10 05-11-07 05:10 PM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Help! Help! please, ignition problem cwachang SV Talk, Tuning & Tweaking 1 17-07-06 10:41 PM
IGNITION stewboy SV Talk, Tuning & Tweaking 14 15-01-06 01:08 PM
