#11 |
When you pull the leaver this is transferred to the worn drive which converts your pull into a push. So you are engaging the clutch.
You should have about a inch to a inch and a half of play in the leaver for a nice setup. |
#12 |
So if a clutch is not disengaged fully when the lever is out how would you tell?
#13 |
Well its all a matter of experience, and feel. Mostly stiff/clunky gear selection, its a bit hard to iron down.
#14 | |
Sorry to be so pedantic here...just once i get a question in my head and all that ![]() |
#15 |
Well no, as other factors come into play when your riding, like what gear your in, chain, wear/lube/adjustment. Even the road surface, tyre wear, riding style. Where as when your not moving these things have limited factors. You tend to find when your not moving everything feels OK and the set-up right, but you get going and its all clunky, and in other situations that reverses. While there is a logical explanation to get to the source of the problem, its take a bit of trial and error to now it down. In addition not all bikes are the same, how it feels on the SV might not be the same on another bike due to the way the clutch is set-up. The wife's Duke clutch is hydraulic and feels heavier, and the action to the clutch is more direct, and almost feels a clunkier box. Where as I find a nice setup SV clutch light and smooth, with only occasionally clunky first and second. So when it get clunky its a warning sign to me that something is up, and probably needs adjusting.
#16 |
Thanks for your time any patience Grinch
#17 |
I'm just waiting on someone to come along and tell you everything I said was rubbish and its all really this...
#18 | |
Lever out = clutch engaged. I think Grinch's talk of the worm drive may have confused you a tad. If a clutch is dragging (not disengaging fully) to any meaningful extent, you'll probably notice the bike pulling forwards whilst stationary but in gear. If it's slipping, or not engaging correctly, then with the lever out you might find the revs rising without the speed of the rear wheel increasing accordingly. |
#19 | |
Mine does...... |
quick question | Quedos | Idle Banter | 4 | 10-09-08 02:14 PM |
Quick Question??? | ASM-Forever | Thames Valley | 7 | 16-11-07 11:43 PM |
Quick Question | DarrenSV650S | Bikes - Talk & Issues | 1 | 12-11-06 02:17 AM |
Quick Question, Quick Answer | JakeRS | SV Talk, Tuning & Tweaking | 6 | 07-05-05 11:00 PM |
Quick question | Yams | SV Talk, Tuning & Tweaking | 10 | 07-03-05 06:29 PM |
