Old 18-12-08, 08:14 PM   #11
Baph
Default Re: Red Rubber Grease
I was under the impression that you used RRG because it wasn't petroleum (mineral?) based. Where's banana.
I'll be the first to admit I could of got my bases mixed up. That's why I said don't use it on my say so.
Old 18-12-08, 08:31 PM   #12
Spokey
True
Red rubber grease is based on vegetable oil - designed to not rot rubber and be suitable for use with glycol brake fluids ( Dot 3,4 and 5.1 )
Mineral oil greases such as Lithium multipurpose can damage the rubber seals.
DESCRIPTION
Castrol Red Rubber Grease is a medium consistency grease based on a vegetable oil and a synthetic gelling agent. It is fortified with additives to improve its resistance to oxidation and corrosion.
APPLICATION
Castrol Red Rubber Grease is formulated for rubber to rubber lubrication where any effects such as hardening or swelling of the rubber must be avoided. It can therefore be used on automotive hydraulic brake and clutch components where compatibility with natural rubber and SBR seals is involved. It may also be used to assist assembly of natural and synthetic rubber components for automotive brake and clutch systems and suspension units.
BENEFITS
S Compatible with natural and synthetic rubber S Good anti-corrosion properties
TYPICAL PHYSICAL CHARACTERISTICS
    • Appearance
Red, smooth, buttery
    • Base
Vegetable
    • Oil Viscosity @ 40ºC, cSt
Not relevant
    • Normal Temperature Range, ºC
-40 to 110 (for Lucas applications)
    • NLGI Classification
3
    • Drop Point, ºC
>220
    • Worked Penetration, mm/10
245-275
    • Rubber Swell, % volume
70 hour/70ºC + 1.8
    • Neoprene, % volume
70 hour/70ºC + 5.1
    • Butyl Rubber, % volume
70 hour/70ºC + 1.1
plenty of RRG on Ebay
In theory, you could use Mazola, or spry crisp and dry ... would be a bit dribbly though
Spokey ( previously Banana )
Old 19-12-08, 12:54 AM   #13
Lozzo
Originally Posted by Spokey View Post
True
<snip>
Hmmm, no mention of its suitability with latex and any danger of damage to skin
Old 19-12-08, 02:34 AM   #14
Dunno, I try to keep it off my hands.
Old 19-12-08, 01:00 PM   #15
AndyBrad
what about using that silicone grease? We use it to assemble lipseals where i work.
Old 20-12-08, 01:01 AM   #16
Lozzo
I always use nitrile gloves when handling greases
red rubber grease steveg SV Talk, Tuning & Tweaking 20 16-12-08 05:12 PM
Grease - all you could ever want to know ? Spokey SV Talk, Tuning & Tweaking 9 22-10-08 08:01 PM
Castrol Red Rubber Grease. BillyC SV Talk, Tuning & Tweaking 16 18-07-08 11:16 PM
Red Rubber Grease leegriffiths128 SV Talk, Tuning & Tweaking 9 10-04-06 05:51 AM
grease latts650s SV Talk, Tuning & Tweaking 2 24-02-06 07:20 PM
