Old 25-12-08, 12:38 PM   #11
petevtwin650
Default Re: Fancy curvy top yoke on ebay
Originally Posted by svdemon View Post
Is that a standard curvy yoke? I must be too engrossed in the high tech world of pointy ownership to have noticed.....
Yes that one on ebay is a faired OEM curvy yoke. Just everything on curvy is that little bit nicer you see.
Old 26-12-08, 10:21 AM   #12
just a question ..... do you need owt special in the way of torque bits for the ignition barrelto get your top yoke off...Im Indoors is putting the precious on Suzy today
Old 26-12-08, 11:07 AM   #13
Sean_C
A security torx bit to get the barrel off. Unless you flatten the shaft in there, then you could use an ordinary torx bit.
Old 26-12-08, 01:55 PM   #14
daved407
That dizzyblonde is not just a yoke its a work of ART. I was full of emotion when I saw that.
Old 26-12-08, 02:22 PM   #15
Dave20046
Dave20046's Avatar
5mil (security torx) I think. You'll need a ratchet with the bits I would have thought - mine was seized in solid, bent an allan key style one.
Old 26-12-08, 03:34 PM   #16
Dangerous Dave
Looks like a normal one with a gay sticker?
Aye it is....
Here's another fancy top yoke, not as good as the one above though
Old 30-12-08, 11:30 PM   #17
transparent_opacity
I've just been trying to fight with mine tonight. Snapped first security torx bit trying to do it properly, then I got rid of the pins only to round the bolt off with a normal torx bit
Need to get it under the pillar drill to take out those bolts neatly....undone the top yoke clamp allen bolts, undone the clipons from the yoke, taken off big chome dome-top nut....stuck fast! What's the knack? The yoke won't come up.
Old 31-12-08, 02:11 PM   #18
Persuade it gently with a moderately sized hammer and a lump of wood.
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
Rather nice top yoke for a Curvy petevtwin650 For Sale - SV's and SV related items 33 25-09-08 12:20 PM
Top yoke for naked curvy gc350 Stuff Wanted 3 28-08-06 12:23 AM
New SVS top yoke fits curvy SV? zunkus SV Talk, Tuning & Tweaking 0 18-08-05 05:18 PM
