Old 07-01-09, 11:30 PM   #11
Default Re: sv s dynojettin ?
http://forums.sv650.org/showthread.p...on#post1352474
check that thread for some details of various systems.
Probably, but a simple phone call will be the easiest way to find out.
Old 09-01-09, 04:59 PM   #12
Even with a full system, rejetting and filter you don't get an awful lot of power tbh. It's a fairly big investment of cash and time to do for not enough gains IMO. If you want to pep the bike up a little, the cam swaps are around £120, take about the same time to fit, and have no setup worries, for about the same benefit. But then again, tuning an SV is a bit like putting a pig in lipstick Just because some of us do it obsessively doesn't mean it's a good plan, we're just a bit dim
Old 09-01-09, 05:05 PM   #13
GOZA
cheers mate mite go for tht then the reason i wanna tune my 650 is cos i fort yer ill just get a 1000 but it feels like a completly diffrent bike. wot cams have u used mate ?
Old 09-01-09, 06:11 PM   #14
spk nglish s i kno wt ur on abwt u twt.
The cam swap mod he talks about is where you use the slightly hotter intake cam from the pointy, and the intake cam from the curvy as an exhaust cam.
This is pretty cheap and moves the power up a bit, makes the last 1000rpm worth using and doesn't affect the mids too much.
Or you can go a bit better than that and fit the stage 2 cams from JHS (or others).
Cams and exhaust +filter are complementary.
Old 09-01-09, 06:34 PM   #15
GOZA
cant seem to find the cams on the web site could you post up a link please
Old 09-01-09, 06:38 PM   #16
http://www.jhsracing.co.uk/archive/start.htm
Old 09-01-09, 06:45 PM   #17
GOZA
cheers mate . do u think the blue flame system will be up to the task with cams, filter and jetting done. because i know its a budget system
Old 09-01-09, 06:45 PM   #18
I have no idea, never seen one never mind dyno'd one.
Old 09-01-09, 06:52 PM   #19
GOZA
advanced ignition, filter, pipes, jetting and cams it is then
Old 09-01-09, 07:28 PM   #20
You don't need the offset timing key. Simply elongate the holes on the pickup. Free mod!
I reckon a head skim or thinner gasket will give you moh powah than advancer. I'm not sure the advancer does much of anything....
