Old 03-02-09, 09:19 PM   #11
sv650nutter149
Default Re: Exhaust and paint questions.
Originally Posted by Dangerous Dave View Post
I'll answer this one for you...
The M4 link pipe is a smaller diameter, you will need to sleeve down the Scorpion inlet pipe to fit it.
its not the link pipe i need to know bout its the link ipe on the scorpion
ta
Old 03-02-09, 11:03 PM   #12
skyline
Default Re: 3 questions.
I really mean this, unless they come off easily and immediately;
DO NOT try harder to undo them.
DO NOT try to remove the studs along with the nut.
Both methods run an extreme risk of snapping the stud. Cut alongside the thread with a hacksaw or similar to split the nut and then remove it, then clean up the thread, even if only with a wire brush.
Sorry to be thick here, but what did you mean by cutting alongside the thread - did you mean actually cutting into the nut, or cutting under it to take away the nut plus the part of the bolt it's attached?
Old 03-02-09, 11:12 PM   #13
scottjames
im pretty sure he means just cutting through the side of the nut. this releases the tension in the nut. then it should come off fairly easy. hopefully
Old 03-02-09, 11:19 PM   #14
skyline
Aaaahh got it. Cheers!
Old 04-02-09, 11:04 AM   #15
Dangerous Dave
ta
No, the link pipe will also not fit the M4 headers as the M4 is a larger diameter.
Exhaust questions JohnK Exhausts 5 02-12-07 06:17 PM
Exhaust Questions UKStreetFighter SV Talk, Tuning & Tweaking 3 18-07-07 12:06 PM
a couple of questions re winter protection / paint steveg SV Talk, Tuning & Tweaking 1 29-10-06 09:33 PM
Exhaust questions and E-Bay thor SV Talk, Tuning & Tweaking 7 07-05-05 11:07 PM
Exhaust Questions AlfBoy Exhausts 1 14-08-04 11:46 PM
