Old 07-02-09, 06:56 PM   #11
Lozzo
Default Re: The screws holding the plastics on
Originally Posted by hob View Post
Set screws can be fully threaded too ?
Set screws are always fully threaded - bolts are threaded usually for the last 2/3 of the length of the shaft, with differences for special applications.
Old 07-02-09, 07:18 PM   #12
hob
So set screws are basically a normal bolt with zero grip length, i.e zero shank?
Old 07-02-09, 07:20 PM   #13
Dave20046
Dave20046's Avatar
Talk about a derail which idiot provoked this.
Old 08-02-09, 11:56 AM   #14
madness
Err..... You did!
Old 08-02-09, 01:53 PM   #15
Viney
The only thing i can imagine is that you have the ones at the back of plastics (Un under the grab rail) mixed up with those ones. I am sure that one set are longer than the other.
Old 08-02-09, 10:43 PM   #16
xbox650
as stu says . I use M6 dome headed bolts .
Rear Brake Pad Holding Pin Seized madeye SV Talk, Tuning & Tweaking 9 14-12-08 02:49 PM
Avoid Points by Holding More Than One Licence I'm_a_Newbie Bikes - Talk & Issues 10 22-09-07 02:11 PM
Torque for fork-holding-allen-bolts? Nekkid SV Talk, Tuning & Tweaking 4 11-05-07 10:34 PM
Those clips holding the brake pads in... tigersaw SV Talk, Tuning & Tweaking 4 09-02-06 01:31 PM
