Old 16-02-09, 11:09 AM   #11
Stu
Trinity
Stu's Avatar
Default Re: Ah. The sound of a V-Twin with fresh oil.
It's fine thanks
Old 16-02-09, 12:48 PM   #12
jambo
jambo's Avatar
While I've found in the past that a sump full of clean oil can make gear changes a little slicker, I'd possibly worry if the bike sounded drastically different after a change.
Jambo
Old 16-02-09, 03:17 PM   #13
MattCollins
Yes, but if it sounds drastically different after the change it could be just the bike telling you to change it more often.
Old 17-02-09, 09:39 PM   #14
rossinio
I need to do an oil change really as hasn't been changed since I bought bike last april (about 2500-3000 miles i think). Busters have an offer on at the moment http://www.busters-accessories.co.uk...?catRef=902041 is this the oil I should be using? Is there a good tutorial online for changing the oil on a K5 pointy S?
Old 18-02-09, 12:32 AM   #15
Stu
Trinity
Stu's Avatar
That oil is fine, but postage at £5 . I hear Hein Gericke sell oil for £14.
I would change the filter every other oil change so if you don't know if that was done you need one of them. You're supposed to change the sump plug washer every time. That's probably overkill, it's up to you. Should be able to get all from your Suzuki dealer.
warm the engine a bit first, switch off have a catch tray under the sump & remove the sump plug 17mm IIRC, remove the filter if you want to, allow to drain, replace sump plug & washer, if you removed the oil filter make sure you removed the rubber seal, put some fresh oil on the new rubber seal & hand tighten the oil filter. pour the oil into the oil fill hole in the clutch cover, check oil level with bike both wheels onflat lvel ground & bike upright (not on side stand)
Old 18-02-09, 12:55 AM   #16
xXBADGERXx
Don`t forget that it is supposed to be run for a little bit and then allowed to settle for 3 minutes and then have the level checked , takes about 2.3 litres to fill her up (on K3 onwards anyway , dunno about Curby Sv`s)
Must admit that around the time my bike is ready for an Oil transfusion she feels a bit "tight" if you get my drift . Once it`s done she feels a free`er and a bit zippier , but only a little
And Stu , I always drop the damn plug into the drainer as well , isn`t the Sump plug 15mm ?
Old 18-02-09, 11:23 AM   #17
injury_ian
Sump plug on my two K4 /K5 are both an Allen socket.
Copper washer can be reused buy heating it to red hot and 'quenching' it under water. it will make the copper soft again.
As per previous guides, I'll tick the bike over to 50-60 degreesC then drop the oil. you dont want it too hot to burn, or too cold that you''l be waiting years for it to flow.
You can do an oil filter change with lowers attached.
when putting new filter on, as stu said, wipe seal with oil, but don't screw it on too tight or you'll never get it off next time, it doesn't need a lot to seal it. And its a filter every other oil change (all in your handbook)
Old 18-02-09, 03:13 PM   #18
Stu
Trinity
Stu's Avatar
Not on my ZX it's not
That's good for a final check, but I would want to see some oil in the window before I started her up
I would have guessed at more even if you didn't change the filter. To be safe I would make sure you had the best part of 4 litres availbe before starting the job
Ahh! I think you have the makings of a knowledgeable biker there! The decline must be so gradual to me that I don't notice nuthink
Old 18-02-09, 03:25 PM   #19
hob
Strange, I was going to post this too, bike just came back from a service and she is definitely happier
Old 18-02-09, 05:38 PM   #20
xXBADGERXx
For some reason mine is a Hex head that takes a 15mm socket and has a magnetic tip on it . My crush-washer is Aluminium on mine , I just flip it over and tighten down onto the lip formed from a previous install
Fresh out of the wrapper Biker Biker Idle Banter 57 14-12-07 02:40 AM
WSB Pics Fresh from Donno John 675 Photos 5 01-04-07 08:14 PM
Fresh meat CmdChicken Idle Banter 8 24-05-06 07:27 PM
Fresh Meat!! Frank O Idle Banter 7 16-01-06 09:47 AM
SV twin port ART can sound Grinch SV Talk, Tuning & Tweaking 11 18-01-05 11:00 AM
