Old 03-03-09, 05:11 PM   #11
gettin2dizzy
Default Re: Fuel Guzzling Bugger! :(
It doesn't sound right tbh. Whack the plugs out. It's an easy enough job
Old 03-03-09, 05:14 PM   #12
Sally
Will Do.
Will report back in later tonight
Old 03-03-09, 05:20 PM   #13
BBadger
Does sound abit suspisous ....althought if your riding it taps open the whole time i wouldnt be supprised.
Old 03-03-09, 05:23 PM   #14
FI int. kit doesn't work properly with EFI.
Old 03-03-09, 05:26 PM   #15
Red Herring
Red Herring's Avatar
I only get 70 - 80 miles before the light comes on, nearly caught me out on Sunday when I then had to do 15 miles to get fuel, and it then took over £15 worth!! Mind you it is a toy and does tend to get ridden like one.....
Old 03-03-09, 05:36 PM   #16
suzsv650
Restriction should give you more much more... I was getting 150 - 170 restricted then de restricted was getting 120 normal riding about ~100 thrashing.
R6 gets about 10miles per £1.. if you use the power band lots that changes....
Dont even ask about the car
Id say look at ur plugs get ur wheels off the floor and make sure they spin good n propper. Check your tyre pressures and keep that chain lubbed!
Old 03-03-09, 05:39 PM   #17
jambo
jambo's Avatar
It's not all about revs.
If you ride smoothly and plan ahead you can get quite impressive fuel economy. If you're all hard acceleration and braking, even if the revs don't get that high, your fuel economy will suffer.
The smoothness tends to come with experience
Jambo
Old 03-03-09, 05:41 PM   #18
suzsv650
Jambo
+1 however i think revs also contribute quite a lot.
Old 03-03-09, 05:43 PM   #19
Revs = potential airflow
Throttle vs revs gives you fuel flow but it's not a straight line... Paggering the throttle at tickover and making it lug everywhere will use loads of juice too.
As will fitting a POS 33bhp kit which limits airflow but does not stop the ECU dumping in the normal amount of juice.
Old 03-03-09, 05:43 PM   #20
As Martain Lewis says "its a money pedal in a car the harder u press it the more u spend"
Bugger valleyboy South & West Surfers 68 23-05-07 12:26 AM
Bugger Ward8124 East Anglian Revolution 4 27-10-06 03:06 PM
Err bugger Im on. . . Diveboy Idle Banter 7 12-05-06 11:55 PM
Bugger Ward8124 Idle Banter 12 09-03-06 05:48 PM
OH BUGGER !!! Jelster Soho Massive 70 28-10-04 08:00 PM
