Old 04-03-09, 04:10 PM   #11
Daimo
Default Re: Checking my oil level
Manual says that? What a peice of poop they've written
Warm engine = oild still around engine
Plus its thinner
It'll be all over the gauge screen too.
check your oil on a cold engine, as you would chekc your tyres before riding otherwise it give s a false reading.
On my curvey model, I found the oil level would drop around 3000-3500 miles (service intervals are every 4000 miles) so be weary. Failure to watch this can lead to oil starvation and a ruined bottom end...
Especially if your haivng a top speed run against a Honda Hornet
Old 04-03-09, 04:16 PM   #12
hmmm wouldn't wonder if thats why so many curvy clutch covers end up leaking, cause there is so many people over filling their bikes!
Having been one that has got a bike thats done both end of the scale( over fil and low oil engine blow up)....I think I'll stick to checking my oil properly, as i've pretty much learned the hard way!
Old 04-03-09, 04:17 PM   #13
ophic
ophic's Avatar
iirc it says something like, run up to temperature, switch off, leave for 3 mins, then check the oil. Mind you this is for a pointy.
Silver SV650SK3, Fuel exhaust
Old 04-03-09, 04:19 PM   #14
Thats more than acceptable Ophic, probably need to leave it a little longer than that to cool off. If I'd have been out on the bike I'd leave it a good half hour before checking it. The engines still fliipin hot even after so long
Old 04-03-09, 04:21 PM   #15
ophic
ophic's Avatar
The oil is thicker when cold and also more dense, so would take up less volume when left long enough to settle. So you're more likely to overfill it when its cold.
Old 04-03-09, 04:26 PM   #16
Luckypants
Luckypants's Avatar
Indeed, had this issue with local Honda dealer. I pulled half a litre of oil out of the bike the night before leaving on last year's Euro trip! Check with warm oil, but allow 5 minutes after switching off for oil to drain back in to sump.
Old 04-03-09, 04:29 PM   #17
timwilky
timwilky's Avatar
It is difficult to see the level through the sight glass if you have lowers fitted on an SV. I used to end up using a small torch
Not Grumpy, opinionated.
Old 04-03-09, 04:39 PM   #18
Daimo
Personnally I adjust the oil when its cold.
Fire it up, turn it off again (this forces the oil round the engine).
Then leave it to settle again ensuring its at the top mark.
Oil death on mine was due to the silly hot summer, and the level dropped quicker than I thought i would coming up to the service. Total my bad.
Don't do the same, its a good days work to getthe engine out of an SV and swapped over with another. Gives you the chance to make it showroom clean again though
Old 04-03-09, 04:41 PM   #19
ophic
ophic's Avatar
I think the difference between the high and low marks is greater than the difference a hot or cold engine would make. So if you fill to the middle it probably doesn't matter.
Old 04-03-09, 04:49 PM   #20
punyXpress
punyXpress's Avatar
Here is a pic of a pointy (2003 on) engine. It does not matter that it is a newer bike than yours, the oil sight glass is in the same place...
You can see the sight glass at the 4:30 o'clock position on the round generator cover on the side of the engine. (or just to the rear and slightly above the oil filter)
You have a curvy model (2001) and if it has lower fairings, the sight glass is obscured by the fairing and you need to look through a little hole in the fairing.....
But is the generator ??
Checking in Kalessin Idle Banter 15 15-01-09 11:27 PM
checking oil level, engine running or not ricky SV Talk, Tuning & Tweaking 7 23-05-08 06:17 PM
anyone wanna swap my hi level leo vine for a low level one spakmitten Exhausts 1 16-06-06 08:59 AM
anyone wanna swap my HI level leo vince for a low level one spakmitten SV Talk, Tuning & Tweaking 1 16-06-06 05:25 AM
Checking in Grifter SV Talk, Tuning & Tweaking 9 22-01-05 06:47 PM
