Old 11-03-09, 08:43 PM   #11
muffles
Default Re: Changing tyres. Pre problem, problem.
Originally Posted by ooger View Post
The new tyres are going to be £160 delivered, if I factor in a breaker bar, I may as well go and order from, and have them fitted locally for £15 more.
Given this, have you factored in the rest of the costs associated with changing tyres? (assuming you are changing them yourself, I just re-read and am not so sure you are)
Old 12-03-09, 07:17 AM   #12
ooger
Yep:
160 delivered, plus a tenner per wheel including balancing & disposal at a local bike place (I'm not planning on actually changing the rubber, just taking the wheels off) = 180. Plus £15 for a breaker bar to get the axle nut off = 195.
Ride in / ride out at the same place = £195 and a free coffee and chat.
I think I have the answer.
Old 12-03-09, 07:19 AM   #13
ooger
Originally Posted by teriyakimonkey View Post
I'd be more worried about the actual tyre changing. I spent hours tring to break the bead on mine and bent a roof rack bar with the weight of a van on it in doing so. Bead remained unbroken.
Good luck!
Nonnononoonoo.
This is not what I had in mind. Just getting the wheels off was the bag I was aiming for.
Old 12-03-09, 09:12 AM   #14
muffles
Yep:
Nonnononoonoo.
That answers the question then
Bear in mind though that a breaker bar is useful for all sorts! Including future tyre changes
Old 12-03-09, 11:12 AM   #15
monkey
Nonnononoonoo.
Ah I see. Not as tight as me then!
Old 12-03-09, 02:54 PM   #16
The Guru
Yep:
Got mine supplied and fitted by garage for £160.. that was me taking wheels to them.
Old 12-03-09, 04:20 PM   #17
muffles
That's 160/60 & 120/60 right? I got my 180/55 & 120/70 for the CBR for 110 quid (er...fitted by me I mean)
Help: 2nd to 1st gear changing problem AndyL SV Talk, Tuning & Tweaking 18 09-05-11 11:56 PM
Changing down problem. Pokerboy89 Bikes - Talk & Issues 1 21-02-09 04:53 PM
Gear Changing Problem ricky_t SV Talk, Tuning & Tweaking 6 08-08-07 04:41 PM
Problem Changing Down Gears leegriffiths128 SV Talk, Tuning & Tweaking 5 03-04-05 11:32 AM
