#11 |
If you don't swap the filter the oil will be black in a day anyway!
#12 | |
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
#13 |
Every 4000mile , oil and filter. Commuting and thrashing. Often the same thing. I am at just over 20k.
Changing the oil and filter on the other Suzi tomorrow as its been mostly laid up since november. Every 4k on that too. |
#14 |
I'm sure oil isn't ph neutral anyway and who's to say what level of toxins it needs to start doing damage?
Would take some hefty research for the sake of changin your oil.
#15 | |
Oil may not be PH neutral, but over it's use especially lots of cold starts it ends up retaining acids apparently. This is one of the indicators that the oil could use changing. James
#16 |
Dunno what pH oil starts off as, but it has buffer compounds in it to keep the pH fixed. Cold starts put water and acids into the oil. I think these have a bad effect on the viscosity and VI's.
Other stuff is VI compounds which are polymers which unwind with heat, to increase viscosity when hot (gives it it's multigrade properties). These break down over time. There are also solid contaminants too small to be caught by the oil filter an oil change gets rid of. Lots more to it that "ahhhrg my oils gone black!". RTFM.
#17 |
No.
#18 | |
I read in my handbook the service intervals are 4-6 thousand miles, hence why i choose 5000 miles (also makes it easy to keep it up and ties in nice with valve clearance checks) |
#19 | |
![]() RE: oil filters; embee, I used genuine suzuki filters. I may have had a rich-running bike, since I havnt changed the air filter since ive owned it. I have changed it now though. I'll have a go with the choke plungers, it wouldnt harm to clean them up anyway. I'll start changing the oil more regularly aswell; 4000 miles seems like a good plan. Thanks for the replies so far guys |
#20 | |
BTW, for anyone worrying about it this isn't a problem.
MOT Question | DanDare | Bikes - Talk & Issues | 4 | 04-03-08 01:48 PM |
R&G bar end question | lukemillar | SV Talk, Tuning & Tweaking | 1 | 21-03-06 10:27 AM |
Bhp Question | kashby | SV Talk, Tuning & Tweaking | 4 | 07-05-05 11:39 AM |
N.I.P. Question? | Cronos | Bikes - Talk & Issues | 19 | 21-04-05 11:21 AM |
