Old 30-03-09, 06:15 PM   #11
ThEGr33k
Default Re: Does a slightly too lose chain sap power?
Originally Posted by simesb View Post
Careful you don't overtighten it and break it Once is unfortunate, twice is ......
**** I know
Have you ever felt how warm a chain gets? Its not like burn your figure hot but it does warm up enough to be felt!
Just shows how much friction there is even when oiled well. So if its not oiled friction and heat must jump BAD! Maybe my bad positioning of my scott oiler last time = not enough oil at some point = too much heat = the snap I got. It was as though heat had caused the link to break
So take it from me, make sure its oiled!!!
Old 30-03-09, 06:20 PM   #12
well yes, I always oil my chain after a bit of a ride...ever heard the lube sizzzle as its sprayed on it? Gets well hot..lol
Old 30-03-09, 06:20 PM   #13
Dave20046
Dave20046's Avatar
**** I know
Yep, gotta be warm to lube em
Old 30-03-09, 06:27 PM   #14
ThEGr33k
Well I think my Snottoiler is cooling it, and with the amount of oil going on all the joins should be more than oiled enough. Keeps the temp down id imagine
Old 30-03-09, 07:57 PM   #15
I doubt it saps power worth mentioning.
However, you've just raised the ride height, which means the swingarm is pointing at a greater angle downwards, meaning the chain will tighten more at full bump.
So, in an extreme case you tightening the chain means that at lets say half compression (full chain extension with normal positioning of spindle vs sprockets), you've just locked the suspension. Explaining your unexpected wheelying, as the power surge normally squatting the rear has now gone straight into the chassis!
I believe TL's were prone to this behaviour with the chain slack set as per the manual.
So, after adjusting the ride height, wind the rear preload as far off as it'll go (without removing the spring...), and use a ratchet strap or something to compress the suspension all the way to the bump stop, make sure the chain ends up with a little bit of slack all through it's movement. Otherwise I see another long wait at the side of the M6 for g33k boy and his flaco!
Old 30-03-09, 08:11 PM   #16
BanditPat
Aren't you restricted pat?
(nah-nah-naaah)
The bike doesent need restricted because its bang on 33bhp at the back wheel... and if you redline it (18k revs) and drop the clutch it comes up a wee bit =]
Old 30-03-09, 08:23 PM   #17
Dave20046
Dave20046's Avatar
oh are you the one on that 400?
Old 30-03-09, 08:26 PM   #18
BillyC
BillyC's Avatar
Does a slightly loose chain sap power? Yes, of course, there's more deformation of the chain, from which it must recover. It also doesn't do your gear changes any favours either.
Old 30-03-09, 08:29 PM   #19
aahhh cheers Gr33ky, you reminded me that Im Indoors drained my can of green snot lube...must be off to halfrauds for some more
Old 30-03-09, 08:34 PM   #20
punyXpress
punyXpress's Avatar
Too much chance of the Fuzz on the chin
Really cannot think of anything to say!
Now: Street Triple R
groggy startup and lose of power with backfiring hbaden00 SV Talk, Tuning & Tweaking 2 19-06-07 08:09 PM
Lose (it's raining) gsv Bikes - Talk & Issues 8 17-06-07 05:21 PM
Anyone else here trying to lose weight? Razor Idle Banter 111 08-03-07 05:07 PM
Power Commander power graph print outs. JimPSV SV Talk, Tuning & Tweaking 19 27-11-06 09:39 AM
Where can you lose oil from? TSM SV Talk, Tuning & Tweaking 15 13-08-05 10:38 AM
