Old 06-04-09, 06:20 PM   #11
Default Re: Best way to clean up brake pistons?
Those ones look pretty grim... Is the second from left flaking, or is it just the photo?
Old 06-04-09, 09:41 PM   #12
monkey
Default Re: Best way to clean up pistons?
Yes and a scotchbrite pad
Can they be overdone with cheap Cif, a scotchbrite pad and elbowgrease or will it never scratch the surface? (Are scotchbrite pan scouring pads?)
Old 06-04-09, 09:42 PM   #13
I'm_a_Newbie
I have 4 new pistons I can sell if somone is interested. I paid £76 only a few weeks ago and never used them, mine cleaned up OK with some wire wool.
As a time served qualified mechanic I can assure you that using red rubber grease on the pistons is fine. It is basically vegetable oil that contains a thickener. Within a few days any excess that gets behind the seals is disolved into the brake fluid. If you are worried about it a bleed after a few days will get rid of it, you will notice the fluid is slightly red in colour.
A further bleed after a few days is a good idea anyway after a strip. I manegd to get more air bubbles out of mine.
Tim
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
Any QUICK way of getting brake pistons to retract? goof SV Talk, Tuning & Tweaking 8 24-06-06 07:10 PM
scaring on brake pistons huge SV Talk, Tuning & Tweaking 2 13-01-06 04:32 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
