Old 24-04-09, 06:16 PM   #11
davepreston
Default Re: problem
sould be easyier than that mate new spark good clean of the plug area (get out all the crap and water) i had the same problem on mine but after the clean and a fender extender she runs sweet as a nut now, also try upping the idle speed for a week or so (helped with mine) it just the wee disc on the right hand side of the engine just below the bikini fairing
turn it clock wise to up it anti to lower
Old 24-04-09, 06:18 PM   #12
davepreston
Default Re: problem
also make sure the ht leads a fully seated and not loose at all
hth
Old 24-04-09, 06:45 PM   #13
matt_rufus
Default Re: problem
it has a fender exstender on her already. and when i got her her tick over was about 1k over what it should be so i'll give it a go and see what happens
thanks dave for the tips.
but the spark isn't big and it is dark with the odd flash of orange which isn't right could it be a dodgy ht lead or a loose earth maybe?
Old 24-04-09, 07:05 PM   #14
davepreston
Default Re: problem
simple test take out you other sparkplug and stick it in if it sparks the same think earth or ht if not its just the sparkplug itself but trust me on the clean out its worth doing every 3-4 months if like me you commute in all weathers
Old 24-04-09, 07:06 PM   #15
davepreston
Default Re: problem
also where u at ,maybe a friendly orger could nip down and have a look at it for you if there local
Old 25-04-09, 08:24 AM   #16
matt_rufus
Default Re: problem
ok hope it works i'll give it a go in a mo, i dont fancy spending 85 squids
i live in the deepest darkes of eltham
Old 25-04-09, 11:02 AM   #17
matt_rufus
Default Re: problem
ok i think i have a dodgy ht lead
i took the coils off swapped them around checked them good nice bright blue sparks from both plugs with the wires not stretched at all, put the bike back together still the same problem so checked the plugs with the bike more intact the rear is nice and bright but with the front ht lead with the rad pulled out the way and testing the spark on the right of the frame it is putting out a orange spark!
Old 25-04-09, 01:55 PM   #18
matt_rufus
Default Re: problem
re checked all my ht leads and plugs i have two good sparks now i havent got a clue where to look next
what else could cause the bike not to be able to run properly?????
Old 25-04-09, 07:31 PM   #19
matt_rufus
Default Re: problem
DONE IT the bike works now i think during the back fire it disloged the carbs slightly and gave it an air leak
put a stainless oval ccc exhaust on though i have to get a decent clamp for it atm it look like the previous owner used a scaffold pole!!
many thanks for the advice from the ppl on here though !
There seems to be a problem... gettin2dizzy Idle Banter 10 28-04-08 10:51 PM
i have a problem... maff Bodywork 15 29-05-07 07:22 PM
I need your help with this problem! 1-3-2-4 SV Talk, Tuning & Tweaking 6 25-09-06 01:45 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
