Old 23-04-09, 09:37 AM   #11
DanAbnormal
Default Re: Skiddy rear tyre?
Originally Posted by chompy View Post
too much front transfers the weight forward off the rear tyre so the rear tyre is lighter there fore less pressure to make the rear skid
You'd have to be almost doing a stoppie for this to happen. As with a tiny amount of too much rear will lock it with ease.
Old 23-04-09, 09:39 AM   #12
Razor
If there are skid marks, wipe more carefully...
Old 23-04-09, 09:40 AM   #13
chompy
not really i was coming up to traffic lights that changed quickly i wasnt consentrating and i put on the front hard, only tapped the rear and it skid and i wasnt anwhere near a stoppie but your right a little too much rear can also make it lock
Old 23-04-09, 09:42 AM   #14
DanAbnormal
Exactly, you braked hard (you hooligan) . I think the OP was implying under normal braking conditions but I could be mistaken.
Old 23-04-09, 09:43 AM   #15
ophic
ophic's Avatar
Originally Posted by KeithCRM View Post
If the road's dry and you're riding steady there's no way the tyre will be skidding. Try checking front tyre pressure, wheel alignment etc. Pressures should be 33 front, 36 rear.
These pressures are only for the stock tyres. Other brands can vary. eg Conti recommend 36/42 for their RoadAttacks.
Originally Posted by DanAbnormal View Post
Surely you mean too much rear brake pressure.
Might be a bit more complicated than that. If you're braking with the front, taking the weight off the rear wheel, at the same time as downshifting without blipping the throttle, I can see that the rear might lose traction. If you're driving it like a car and doing this just as you turn it in, then the bike will be all over the place, hence feeling like you're about to lose control.
Silver SV650SK3, Fuel exhaust
Old 23-04-09, 09:44 AM   #16
chompy
lol i know im such a hooligan next ill be going 1 mph over the limit
i dont think the op has explained what conditions it was under ect ect
Old 23-04-09, 09:45 AM   #17
Dave20046
Dave20046's Avatar
</p>
I can't find what dunlop recommend for mine, so just run 36/34 ...</p>
Old 23-04-09, 10:58 AM   #18
Ginger 1
To be fair Im using avons and have used Conti's and found out when I change down (Only one gear) and use engine breaking it does tend to lock up a bit. I just assumed it was part of the curvey.
Old 23-04-09, 11:00 AM   #19
Berlin
Too much front brake is unlikely to be the reason. Unless he happens to be a GP rider.
As suggested, Engine braking is the obvious candidate followed by oil on the tyre, followed by too much rear brake but as we don't know the "certain circumstances" then we'll have to wait for more info (like thats ever stopped anyone )
C
Old 23-04-09, 01:59 PM   #20
lmfy2k
Thanks for the info guys, will be riding out on weekend so will fill you in with more info.
rear tyre plowsie Stuff Wanted 4 15-03-09 10:15 PM
Rear tyre available RGV250ads SV Talk, Tuning & Tweaking 0 15-08-08 01:58 PM
180 rear tyre on a 650 ?? SV-net SV Talk, Tuning & Tweaking 13 19-01-08 07:25 PM
170 rear tyre on SV CHICKENSTRIPS SV Talk, Tuning & Tweaking 9 24-07-07 01:27 AM
How much is a rear tyre for you? JakeRS SV Talk, Tuning & Tweaking 5 06-06-06 02:43 PM
