#11 |
Hmmmm all very strange, I hadn't actually removed the carbs but checked the cables and made sure they were closing properly. Dunno if upon looking I had done anything but it all seems well now, reving and ticking over, so a big thanx to all.!!
#12 |
I remember when I accidently crossed over my CBR throttle cables when I took the carbs off, that was errr......interesting
#13 |
Mine is running, sounding really quite cool, big throaty growl, but the cylinders still seem to be in the huff with each other and "hunting" I think best describes the idle.
#14 |
If the carbs wouldn't balance up you need to check the idle mixture screws and the valve clearances.
#15 |
Idle mixture and valve clearances???? eeeee god the plot thickens, gonna try and get a working set of gauges and try again, hopefully that will be all that is needed.
#16 |
There is also the possibility of knackered gauges!
Bear in mind the reading is pulsing naturally (4 stroke cycle, innit). Did you have the damper screw closed far enough?
#17 |
Yeah I turned it as far as it would go one way and then tried it the other but they still fluttered or rather spun round this way and that. I think the gauges were err very cheap off flea bay so I'm happy enough to presume them duff.
#18 |
I don't get this at all!
I've taken the air box off to get to the adjuster screw on the carb and now it won't tick over and if I rev too hard it just cuts out. I had another go with the gauges, as pointed out to me I hadn't set them up properly (tube into valve then into gauge ) but now it won't tick over at the appropriate speed for me to adjust. Can I rev a little and adjust from there or does it have to be done with no revs at all? |
#19 |
Turn the idle adjuster up a bit, it makes it far easier to have a stable idle.
#20 |
Just a quick update, apparently I'm a male sexual organ.
When adjusting the carbs, the tank is up and disconnected, so therefore after a wee while it runs out of petrol. DOH! Anyway all done now and running sweet. Thanks for your time a patience. I'm gonna hang my head in shame now. (scuttling away into a corner donning a dunce cap) |
Carb balancing | Grinch | Soho Massive | 10 | 07-05-09 07:44 AM |
Carb Balancing | Tris | SV Talk, Tuning & Tweaking | 9 | 09-08-07 09:47 AM |
carb balancing | Banus | SV Talk, Tuning & Tweaking | 9 | 23-02-06 01:38 PM |
carb balancing | johndo | SV Talk, Tuning & Tweaking | 3 | 08-04-05 05:31 PM |
Carb Balancing | Scoobs | SV Talk, Tuning & Tweaking | 14 | 14-02-05 08:32 PM |
