Old 18-03-10, 10:56 PM   #11
Whitehouse
Default Re: Rearsets
id have to agree, theyr very sturdy and feel solid
Old 18-03-10, 11:08 PM   #12
Nobbylad
Nobbylad's Avatar
I'm happy with my Valtermoto rearsets....then again...they're still in a box waiting to go on
Old 19-03-10, 11:37 AM   #13
lawson17
I have Valter Moto fitted too, their type 1's. They aren't adjustable, and don't like crashing very much either, but they are pretty good for £170.
I bought some other rearsets on ebay before the season started, but they don't fit with the K3 rear subframe. (See 'For Sale' Section if interested.)
Old 19-03-10, 01:05 PM   #14
flymo
flymo's Avatar
Originally Posted by pencil shavings View Post
Im not sure on the clearnace issues people have been talking about, Ive only ever grounded the pegs once on a cambered corner. So clearnace isnt an issue, and thats not because Im not trying, I dont have any chicken strips!
thanks
There must be more lean available in that bike then , I've grounded out a set of race rear sets on a few occasions and they are much higher than stock pegs. In fact last time I did it I ended up on my ar$e at 80mph ....actually, that pic in my avatar was one or two laps before it happened on teh very same corner.
Old 19-03-10, 11:49 PM   #15
Zen Beetle
Two questions:
1. Can the pegs be positioned lower than the stock ones?
2. Will the brake lights still work or are these rearsets mainly for use on track?
Old 19-03-10, 11:54 PM   #16
CheGuevara
With the GB Motos the low setting is still notably higher than stock on the S (which I think would be relatively higher still on the N). I'm 6'4" though and still don't find it an issue for rides of a few hours.
You will need a brake pressure sensor banjo to activate the brake light. It's very easy to install, just cutting the wires to the original and splicing in the new one in place. I got one direct from GB Moto for (I think) and extra £10 maybe.
- K9 SV650S: Hel brake lines, carbon end can
- SZR660: The project...
- K5 SV650S: K7 GSXR750 front end, ZX6RR shock, GB Moto rearsets, Hel brake lines, Renthal risers, Tuono bars, V-Rod headlamp, "JMV" belly pan ~SOLD~ (wonder where it is now)
CheGuevara is offline   Reply With Quote
Old 20-03-10, 12:25 AM   #17
Nobbylad
Nobbylad's Avatar
Hel do the same switch for a few quid IIRC
Old 20-03-10, 01:43 AM   #18
barwel1992
i got a goodridge brake switch
and my GB moto rear set adjuster plates have been swaped over and fliped over so they are even lower than the low setting because i have fat legs and found them wayyy to high on the low setting with the plates the original way round
you will need a custom length rear brake line (for the k3 any way)
Old 20-03-10, 02:07 AM   #19
Stu
Trinity
Stu's Avatar
I would be after a set for more adjustment of the gear changer lever. The setting I have it on at the moment, is too high, if I knock it down one notch it is too low.
See http://forums.sv650.org/showpost.php...52&postcount=9
The connecting bar lets you have infinite adjustment of the height of the gear lever. Doesn't the standard have a connecting bar that works the same way?
Old 20-03-10, 02:11 AM   #20
barwel1992
^ k3+ has the conection adjuster as standard
rearset replacement John 675 SV Talk, Tuning & Tweaking 44 01-05-09 08:32 PM
Looking for: LHS Rearset - 99 Curvy JimmyGulp Stuff Wanted 6 04-07-08 03:41 PM
Rearset bracket plowsie Stuff Wanted 4 03-07-08 10:43 AM
I designed some rearset for SV r4ce_e3nd SV Talk, Tuning & Tweaking 16 10-11-06 09:59 AM
Rearset fitting rigor SV Talk, Tuning & Tweaking 4 11-12-05 05:24 PM
