Old 04-05-09, 08:12 PM   #11
454697819
Default Re: attaching something to a stud wall
these are the ones.....
Old 04-05-09, 09:03 PM   #12
Spokey
these are pretty good for plasterboard
Spokey
Old 04-05-09, 09:12 PM   #13
keith_d
keith_d's Avatar
I've never been a fan of fixing things to plasterboard unless it's absolutely unavoidable, in which case the spring loaded fixings get my vote.
If the top is high enough that people can't see over, screw a suitable strip of wood between two studs and fix the cupboard to it. If not, consider fixing a batten inside the top of the cupboard and screwing it to one of the studs, even off center it'll stop the cupboard being pulled over.
Just my thoughts,
Keith.
Old 04-05-09, 09:23 PM   #14
Frank
What I have done before now with a heavy cuboard ,is to cut a rectangular strip out of the plaster board,that reaches across two vertical studs.Screw a cross noggin to the studs,and then replace the stip of plasterboard.
Dadaaa ,solid as houses
Old 04-05-09, 09:27 PM   #15
So the cupboard isn't wide enough to reach the vertical studs right? So now you will be able to see the plasterboard you cut out won't you?
Old 04-05-09, 09:33 PM   #16
Frank
no...use some "fineform filler" that is used on "tape and joint"plaster board.
2 coats of paint and your away"unless u have wall paper of course"
Old 04-05-09, 09:35 PM   #17
Oh that's far too much work just to get a fixing. Just move the bookshelf to the side a little
Old 04-05-09, 09:36 PM   #18
Frank
ok then...just "pinkGrip" it to the wall
Old 04-05-09, 09:37 PM   #19
Yeh and buy another bookcase when you move house lol
Old 04-05-09, 09:41 PM   #20
Frank
Bracket for attaching clocks rob13 SV Talk, Tuning & Tweaking 3 12-06-08 06:23 PM
Snapped Exhaust stud! spacehog SV Talk, Tuning & Tweaking 4 22-05-08 08:21 PM
At Stud on Ebay :( 21QUEST Idle Banter 5 23-01-07 01:23 PM
Attaching head light covers svrash Bikes - Talk & Issues 2 16-07-06 08:51 PM
exhaust stud dirtydog SV Talk, Tuning & Tweaking 13 14-02-06 04:07 PM
