Old 06-05-09, 03:39 AM   #11
Jamiebridges123
Default Re: Please help
AFAIK a Fender Extender will do on it's own. The silicone should just be an extra thing to do, IMO.
AFAIK i don't have silicon round the front plug socket and in the (very heavy and flooded roads) rain the other week I had no issues.
Old 06-05-09, 06:55 AM   #12
Stewart.C
Thanks alot. Big help.
i will just go buy a Fender Extender right now & do all the other checks suggested just to be safe.
Im out in stonehaven & work in Dyce so bike is a must.
thanks to ya all
stewart
Old 06-05-09, 06:57 AM   #13
simesb
Either will do - I don't like the look of extendas, but the silicone works fine by itself. Make sure the drain hole is clear too!
Old 06-05-09, 07:21 AM   #14
dyzio
dyzio's Avatar
Not quite, I had an extender and the bike refused to start on both cylinders after being left in the rain for the night. This never occurred once I started using the grease.
Do both.
Read this
And buy this in Maplins: Silicone grease, part no. RE90X
Old 06-05-09, 07:23 AM   #15
Stewart.C
ok cheers.
will just do both to be safe.
Old 06-05-09, 07:57 AM   #16
Baz
Think this one has been answered enough but as others have said if you need a hand with anything get on the Aberdeen banter hotline and one of us Aberdeen folk will try to lend a hand.
Old 06-05-09, 10:24 AM   #17
Jamiebridges123
Must check mine as well brb
Old 06-05-09, 11:05 AM   #18
Shellywoozle
Shellywoozle's Avatar
Have you solved the problem now? Hope all is good and you have it running on both now.
Baph put grease on mine at the weekend, its not tested yet but when it rains I may go and try it out. If it works I will have a fender extender for sale (as I am to lazy to fit it LOL)
Old 06-05-09, 11:59 AM   #19
vardypeeps
When you fit your extender use the screws or you might find it goes missing down the road.
Some reason the sticky fixers arn't very good on the sv fender
Old 06-05-09, 12:23 PM   #20
Stewart.C
Default Re: Please help (Solved Thanks )
Hi byes looks like it may be what ur all saying.
Front plug was a bit dirty so gave it a clean & a wee spray.
ticking over fine for just now but as usual its raining up here again so ride home should put it to the test.
