Old 10-05-09, 10:52 PM   #11
Nicky S
Nicky S's Avatar
Default Re: USD GSXR1000 k1 forks | standed forks - curvy
Parts list as promised..
GSX-R 1000 K2 front end:
Forks
Yokes
Callipers 6 Pot
Front Wheel inc good tyre
Discs
Disc bolts
Spindle
Cost £400 eBay
Controls, levers & grips
Top yoke nut and washer
Top yoke pinch bolts
Top yoke castle nuts & washer
Top yoke bearing seal
Bottom yoke pinch bolts
Calliper banjo bolts and washers
Calliper fixing bolts
Brake lines
Master cylinder banjo bolt
Ignition + bolts
Bearings and races*** see bottom
Cost free, re use from SV650
Clipons, Gilles tooling variobar 60mm rise
Cost £73 eBay + £84 for new 50mm clamps (coz I’m daft)
Bottom Yoke pinch bolts, 8mm X 40mm SS flanged head
Cost £6.15 eBay
Front Pads, SBS sintered pads
Cost £32.50 eBay
Mudguard, black
Cost £56.95 Jesters Trick Bits
Mudguard bolts & spacers
Cost £19.97 local Suzuki dealer
Speedo sensor, Cherry switch GS100701, home made bracket
Cost £29.27 RS Components
Bolts & dome nuts to mount Speedo bracket
Cost £5.77 eBay
Magnets, 10mm X 5mm (20 of) I used 8
Cost £10.99 First4magnets
Resin for magnets, Steel Grip 2 part, or something like that
Cost £5.99 Halfords
Tapered bearings, I replaced the bearings for tapered roller type. This was not necessary but since I was removing the front end anyway I thought why not put better ones in that will last longer.
Cost £9.98 eBay
Lower yoke bearing seal, I had to replace this when putting on the new lower race.
Cost £5.48 local Suzuki dealer
will any of that work on my curvy ... also i want k1 forks not k2 forks or are they the same also i still want to use the standed sv speedo and my steering lock
Curvy With Lots Of Bits ...
But Still More To Come
Nicky S is offline   Reply With Quote
Old 10-05-09, 10:53 PM   #12
Aha thems the numbers I was trying to think of.
Bottom is a 32006, top you will need a TWF bearing, as 32005 as standard for curvy won't fit the SRADstem through it.
Old 10-05-09, 10:55 PM   #13
Nicky S
Nicky S's Avatar
SRAD/Kx stem is same. Also same as pointy.
Same steering bearings used for every GSXR since the SRAD.
The curvy uses the old way of doing it with a smaller top race same as the slingshots and about a million other suzukis.
Thus to put SRAD stem into curvy frame or any other older frame you need TWF bearing which has correct OD for frame and bigger ID to fit spindle.
so TWF bearing and srad top/bottom yokes but what year will these yokes have to be to fit a 2002 curvy and GSXR1000 K1 forks ?
Old 10-05-09, 10:56 PM   #14
Any SRAD750 AFAIK
Old 10-05-09, 10:57 PM   #15
GSXR1000 K1-2 are exactly the same forks
Old 10-05-09, 10:58 PM   #16
Nicky S
Nicky S's Avatar
Any SRAD750 AFAIK
AFAIK ???
what other bits will i need from what bike/year and also to get the standed sv speedo to work ?
Old 10-05-09, 10:58 PM   #17
Nicky S
Nicky S's Avatar
kk
Old 10-05-09, 10:59 PM   #18
Brake lines
Ignition + bolts
Cost £9.98 eBay
Bold stuff needs to be gixxer specific. Will not swap from SV - SRAD.
Old 10-05-09, 11:02 PM   #19
Nicky S
Nicky S's Avatar
Bearings and races*** wont this be the part from TWF
take it these will have to come from the same make of bike as the forks so from a GSXR1000 K1
Old 10-05-09, 11:07 PM   #20
has curvy has a different top yoke nut, castle nuts...
pointy stuff fits no problems...
if it were me i would go with GSXR1000/750 K1-5 yokes and drill a new steering lock hole in the stem... but thats me...
curvy forks husky03 For Sale - SV's and SV related items 5 29-10-08 07:10 PM
Curvy forks wanted. skapegoat Stuff Wanted 1 22-01-08 07:29 AM
Gsxr Forks On Curvy CHICKENSTRIPS SV Talk, Tuning & Tweaking 1 18-07-07 05:45 PM
curvy sv forks fit k4 ??? daddy_sperm SV Talk, Tuning & Tweaking 2 24-04-05 07:12 PM
Conversion to GSXR1000 front forks ? Powergaard SV Talk, Tuning & Tweaking 2 21-01-05 12:12 PM
