Old 14-05-09, 12:23 PM   #11
arcdef
Default Re: Fuel light = rough running?
Thanks for the advice guys, will have a look over the weekend!
Old 25-08-09, 07:58 PM   #12
noob-saibot
Sorry to drag up an oldish thread, but i wouldnt mind doing the same. How do i drain the fuel out of my tank and reserve?
Old 25-08-09, 10:37 PM   #13
arcdef
Done mine the other day. I let it run as low as i would dare then lifted the tank, disconected the hoses (not much if any fuel leaked) then lower the tank, undo the hinge bolts, disconnect sensor cable, take off tap from under tank then pour fuel out, put some clean fuel in and shake up a bit then empty again. Then simply re fit!
Old 26-08-09, 08:25 AM   #14
noob-saibot
The tap being the squarish metal gizmo that the tubes connect to?
Old 26-08-09, 08:33 AM   #15
arcdef
Yep, there is a rubber gasket though so be careful not to drop or damage it, it is advised to replace every time you disconnect it though.
Old 26-08-09, 10:10 AM   #16
noob-saibot
Cool. Did you sort out your problem after all?
Old 26-08-09, 12:52 PM   #17
arcdef
in all honesty i have not let it get low again but the petrol that came out was far from clear so must help a little?
rough running ? mikey devon SV Talk, Tuning & Tweaking 11 21-03-09 12:07 AM
Running rough when hot svdemon SV Talk, Tuning & Tweaking 3 13-08-08 07:44 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
Running Rough? mike_b SV Talk, Tuning & Tweaking 3 20-12-06 11:38 PM
Running rough when cold? Fuzz SV Talk, Tuning & Tweaking 0 05-02-06 03:06 PM
