#11 |
I checked before i set off home and the expansion tank was empty..I didnt have any water so watched the temp which was fine..lucky no traffic. Will let it cool tonight and fill up.
The fluid level drops over a period of riding and I never knew where it was going..( head gasket worries but no milky oil..last changed 2 months ago after 2.5k) So top it up via the expansion bottle. I was worried I did something the last time I changed the coolant back last august so drained the coolant again after the oil change and rechecked the banjos at the top of the radiator. Put fairings on recently and have noticed the running temp go up on my way in to work ( running 97-106 as opposed to 86-97 with occasional 105). The fan kicks in and never goes above 106. Today spent most of its time in 97 -106. I'll filll up via the cap and see it much has left the radiator.. thx for the tips
"an unedifying exercise in postmodern, operatic grunge" Was - 2000 Candy blue sv650s -2003 Sonic silver sv1000s Gone - 2007 Wildfire Orange Ninja zx6r Now - 2010 Triton blue sv650s -Back to the future |
#12 |
Your sure the temp is geting higher because the weather has got hotter?
Allso the fairings will make a difference because they will reduce air flow around the engine. Those temperatures don't sound too bad to me. Have you tried bleeding the system? An airlock could potentialy cause funny things to happen. Last edited by shifter; 16-05-09 at 09:42 AM. |
#13 |
i had this same problem on my sv650 but mine was comeing out or the rad cap i later found out that i needed a new rad cap and also that i had to much water in the water tank under the petrol tank
Curvy With Lots Of Bits ...
But Still More To Come ![]() |
#14 |
took the cap off today and added some coolant..started spilling out almost straight away. I checked the expansion tank and after closer inspection it seems that there was some left in the tank.. not sure what this means..it probably means I've been over filling I hope.
Does squirting someone with a water-pistol constitute assault? | SoulKiss | Idle Banter | 39 | 18-06-08 12:32 PM |
Oil in coolant ?! | fatneck | Bikes - Talk & Issues | 16 | 26-02-08 09:14 PM |
Coolant - what to use | Flamin_Squirrel | Bikes - Talk & Issues | 8 | 22-10-07 03:38 PM |
Coolant help | therealvw | SV Talk, Tuning & Tweaking | 3 | 07-08-07 08:02 PM |
Sorry -coolant again | tomjones2 | SV Talk, Tuning & Tweaking | 6 | 17-06-06 09:47 AM |
