View Poll Results: How many miles on your SV? | |||
<10 000 |
14 | 19.44% |
<20 000 |
24 | 33.33% |
<30 000 |
19 | 26.39% |
<40 000 |
7 | 9.72% |
<50 000 |
1 | 1.39% |
>50 000 |
7 | 9.72% |
Voters: 72. You may not vote on this poll |
#11 |
Under 20k (19+ i think) k3 owned since 3k.
In the process of taking it apart for a good clean and check, for forks to get the internals done (cue moaning about the rear) and either paint or polish. Subframe paint. A new EBC disk after it warping or I suspect been damaged by a tyre fitter. One disc dished so got a set of EBC's fitted. Pish in the wet but better in the dry than OE. 2nd C&S kit, 3rd chain (snapped). Oil pressure sensor temporary repaired as a precaution. 2nd speedo drive knackered. Can't be bothered replacing so it gets superglued....and breaks in place, and continues to work. 3 full front brake strips. Winter cack. Used to run on one for a few minutes much to the delight of my neighbours until I got busy with the silicon gel round the front plug cap. Will run it till it goes pop, then use that as an excuse to get summit else... A Gladys 750RR-Z k11. ![]() |
#12 |
The bikes do last well, most of the problems that I have seen have been electrical and in my case very little winter protection.
#13 |
24k miles, nothing gone wroung, only tires, oil and a set of brake pads replaced. Chain and sprockets getting knackered now.
#14 |
I think my old one has done 27K now. The new owner doesnt do many miles though so its only gone up 2K in like 12 months... Mine happily did 12K a year through all weathers all year with long 100+ mile trips regularly.
#15 | |
![]() if anyone says "scottoiler" i'll scream ![]()
Silver SV650SK3, Fuel exhaust |
#16 |
just over 10k now on a 01 sv650s i bought it when it had 5 k on clock. lots of bits replaced(MAINLY FAIRINGS DUE TO CRASHES) nothing changed due to faults
#17 |
#18 | |
#19 |
Commuting distance | Renton | Bikes - Talk & Issues | 21 | 26-06-08 12:56 PM |
Touring Distance? | Jamie_SV | SV Ecosse | 10 | 17-04-08 11:54 PM |
Reasonably Distance togo buy a Car/Bike | SteveH | Idle Banter | 12 | 20-07-07 04:51 PM |
Why you should always keep your distance! | Stig | Bikes - Talk & Issues | 10 | 10-01-07 09:04 AM |
Service - time or distance? | rpwoodman | SV Talk, Tuning & Tweaking | 24 | 24-11-06 12:21 PM |
