#11 |
I don't need to take the cover off on the LHS of engine do I? Just trace the wires back, which come up behind tail fairing on RHS of pillion seat..
#12 |
OK, just tested resistance across the connector plug which leads back to the pulse generator coil. Came in at 189 ohms which is good
Chris how do I check continuity between pulse coil and ICU? One probe in the end of the connector plug loom side, and the other in the respective wire at the ICU connector block? Last edited by joshmac; 01-06-09 at 08:07 PM. |
#13 |
Yes. Or test the resistance directly at the ICU connector.
#14 |
OK that was wierd.. I had continuity from both wires at the connector block when tested individually to the respective terminal at the ICU, but didn't have anything (just read 1) when I tested across just the terminals at the ICU if that makes sense. Any idea why?
#15 |
Dodgy connector? Not got it plugged in?
#16 |
Knob faced knobster
Your SV is broken, i'll give you a fiver for it
2011 Speed Triple 1050 |
#17 |
Its a curvy, you give me a fiver to take it away
![]() Gl fixing it though ![]() |
#18 |
How can I have it plugged in if I'm testing it?
Cheeky sod! You're never to old for a slap ![]() Well, maybe at YOUR age! ![]() ![]() I'll give you £40 to fix my problems though... bike not life before you think you're original and should offer your chair to someone else ![]() |
#19 |
The Sick Man
have you checked that you have not suffered from the curvey loom rubbing through? look at the loom as is passes behind the frame on the left side of the bike, just infront of the battery
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#20 |
If you're testing it at the ICU connector.
Poor Running Engine? (Curvy 99) | vardypeeps | SV Talk, Tuning & Tweaking | 11 | 20-03-09 11:26 AM |
Curvy running funny :( | Dave20046 | SV Talk, Tuning & Tweaking | 24 | 30-09-08 08:52 AM |
Bad starting, poor running, 2000 Curvy. | jtrent90 | SV Talk, Tuning & Tweaking | 15 | 01-07-08 02:55 PM |
grrr headlights | yorkie_chris | SV Talk, Tuning & Tweaking | 2 | 09-12-07 05:17 PM |
Various Running Problems - Solutions - Curvy SV | Hooligan | SV Talk, Tuning & Tweaking | 2 | 05-05-06 08:45 PM |
