#11 |
How much slack you got james?
#12 |
#13 |
check the front sprocks teeth aswell, they wear faster.
#14 |
front sprocket last 13K? how often do people have to tension the chain normally? i generally leave maintence to my mate when hes not to busy, but these days hes too busy to get on his bike so he cant look at mine for me
#15 |
Think thats a take the engine casing off jobby to check? Will have to do it at the weekend no time free really atm. Had a look inside with a torch but if I have to take casing off then I'll give it a clean too.
I measured the slack, my measurement just got under 4cm (3.8cm). Here is my attempted illustration in picture form, with credit to my brother for being near 100% useless. The white mark is where the top of the chain is (measurement line was top of the chain) - 3.6cm Link: http://5wire.co.uk/james/DSCF15701.jpg Then.. 7.1cm Link: http://5wire.co.uk/james/DSCF15691.jpg 3.5cm currently, manual says 0.8 to 1.2inch 3cm, so will give it a tighten a whisker below 3cm and see how it is. Rear sprocket in my opinion is fine, the teeth are still alright not rounded off to a ridculous level. I'll get a second opinion of one of mates who does all his stuff himself, but hes at college 100+miles away at the minute. |
#16 |
Hey! Just come in from fiting a new rear renthal sprocket and checking chain tension.
In those photos above you've got the bike on the paddock stand. You need to check the slack when its off the stand and ideally when your sat on it. This is where you need a mate! Or you can put it on the side stand and lean over the bike from the other side placing your weight over the seat - checking the slack while the blood goes to your head! You need to do this so the suspension is in play. That slack will be partially taken up when you remove it from the paddock stand. Just a question for other thread readers. I've been playing with the tensioners to try and get the chain running evenly either side over the sprocket teeth. Anybody else bother much with this? |
#17 | |
#18 |
RTFM
The 30mm slack on the sidestand is the correct amount for some free play left when the suspension is compressed. Bit more slack will not hurt though. I wouldn't be worried by 40mm.
#19 |
Yes, chain run needs to be straight. This is function of wheel alignment, use 2 straight edges to be absolutely sure.
#20 | |
I might tighten it slightly to get it back nearer the 30mm mark. |
chain question | Wideboy | Bikes - Talk & Issues | 36 | 21-02-09 12:31 PM |
Daft question: How do you use a chain? :) | ooger | Bikes - Talk & Issues | 16 | 07-10-07 08:33 AM |
chain question | shutdown | SV Talk, Tuning & Tweaking | 11 | 22-04-05 06:20 PM |
Chain question | cb5wanabesv650 | SV Talk, Tuning & Tweaking | 10 | 14-04-05 10:13 AM |
Question on chain fitting | Tony_BLY | SV Talk, Tuning & Tweaking | 9 | 23-11-04 02:59 PM |
