Old 22-06-09, 08:27 PM   #11
FishyMug
Default Re: Rear caliper mounting bolts
Originally Posted by FishyMug View Post
I'm looking to do my rear pads soon, i had a look at tastynuts they've got some nice looking gear, but i can't find the caliper mounting bolts on their site, also is it worth replacing the pins with titanium ones? mines a K5
Just to make sure, we ARE talking about the 2 caliper mounting bolts aren't we? does anyone know their size?
Old 22-06-09, 09:47 PM   #12
thefallenangel
pointy ones rust in lessa than a year lol. Will be going for warranty replacements.
Old 22-06-09, 10:01 PM   #13
flymo
flymo's Avatar
There is only 1 mounting bolt on the rear caliper on a pointy. I can check the size once we've confirmed exactly which bolts you are asking about.
Old 24-06-09, 07:23 PM   #14
FishyMug
I've attached a photo, these are what looks like them, no.1 definitely is, and no.2 looks like it attaches the caliper too. any help you can give would be much appreciated
Old 24-06-09, 07:33 PM   #15
flymo
flymo's Avatar
...no.1 definitely is, and no.2 looks like it attaches the caliper too. any help you can give would be much appreciated
Ok, No:1 in your photo is the bolt that fastens the caliper to the mounting bracket. No:2 isnt a conventional bolt as such, it screws into the caliper but the other end of it is smooth (where you would expect there to be a thread). The smooth section slips into the caliper bracket in a rubber boot that normally contains grease. The entire caliper is able to slide back and forth on grease.
So, No:1 can be sourced anywhere, either as a genuine replacement part from Suzuki or as a stainless one from Probolt etc. No:2 is a Suzuki only I'm afraid unless you can find somewhere that makes them in stainless, but thats unlikely.
Old 24-06-09, 08:06 PM   #16
FishyMug
Thanks Flymo! any idea on the size of the mounting bolt? and whether a steel replacement would react with the aluminium mount?
Old 24-06-09, 08:52 PM   #17
flymo
flymo's Avatar
I'll check the size, need to be careful though, dont just replace it with any old stainless bolt. It needs to be high tensile due to the stresses it can be placed under.
Old 24-06-09, 09:05 PM   #18
Spanner Man
Evening all.
Number 1 bolt has a standard M8 x 1.25mm thread, & is around 45mm long.
As said it is a stressed component, & should be replaced with either a standard bolt, or a stainless bolt of a suitable grade.
Number 2 bolt/slider pin has a 12 x 1.25mm thread & is indeed only available as an original part. A similar caliper was used on 1990's CBR600's & I'm pretty certain that the bolt is the same. So if you're stuck for one a Honda dealer may be able to help.
Cheers.
Spanner Man
Old 24-06-09, 09:44 PM   #19
Holdup
Cheers.
Refer to post 2
Although most dealers whether it be Honda or Suzuki are very unlikely to keep it in stock, but it only norm takes a day to be ordered
Help - Front Caliper Mounting Bolts SV Meldrew SV Talk, Tuning & Tweaking 19 11-02-09 08:13 AM
Where can I buy caliper mounting bolts? Binky SV Talk, Tuning & Tweaking 4 07-08-08 10:46 AM
Rear brake caliper mounting bolt $tevo SV Talk, Tuning & Tweaking 12 06-05-06 07:29 AM
Rear Brake Caliper Retaining bolts **WARNING** derbybiker SV Talk, Tuning & Tweaking 11 07-10-04 01:00 PM
