Old 17-06-09, 10:28 PM   #11
Default Re: Attempting to install Dominator lights - confusion about plugs
If fitting from S sub loom there are already 2 H4 connectors, you need to splice sidelight or fit it into whatever connector comes already with the dominators.
If going from naked, you plug the male conector you have hold of in top pic into H4 connector on stock loom, you then need to cut your stock sidelight bulb and fit some female connectors to match dominator ones, or some spades of right size to connect with OEM fitting to the dominators sidelight fitting.
Yes, on top pic, the connectors on the right power the sidelight.
I'm not sure for MOT, I think you need one sidelight, I don't think it matters which side. But I'm not too sure.
Old 24-02-12, 03:44 PM   #12
srobrien
Hey, I am currently installing these exact headlights on my SVS which has 2 H4 plugs for the front headlights. I take it I just need to connect the dominators up to one of these sockets and I can get rid of the other one?
R
Old 24-02-12, 03:47 PM   #13
Yes just hide the plug somewhere, or better plug your 2 wires straight onto the bulbs.
Old 24-02-12, 03:49 PM   #14
srobrien
Thank you kind sir!
Old 24-02-12, 04:28 PM   #15
rictus01
rictus01's Avatar
I take it you're giving up night riding then
Old 24-02-12, 05:13 PM   #16
srobrien
Never ride in the night, never will if possible.
take it they are not good in the dark.
Had them wired up and they seemed pretty damn bright to me.
R
Old 24-02-12, 05:52 PM   #17
rictus01
rictus01's Avatar
they start off " not very good" then craze and get worse....
Old 24-02-12, 06:05 PM   #18
srobrien
Default Re: Attempting to install Dominator lights - confusion about plugs.
Oh well should be ok for my needs..they can't be much worse than the standard curvy lights.
Dominator lights on Pointy? forky SV Talk, Tuning & Tweaking 6 29-12-11 07:21 PM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Are NGK Iridium Sparks Plugs better than standard plugs? Cartlidge SV Talk, Tuning & Tweaking 12 04-09-09 06:45 PM
Recommend me a screen for a naked with dominator lights. bigup SV Talk, Tuning & Tweaking 2 15-05-09 11:11 AM
Dominator Headlights SV650Guern SV Talk, Tuning & Tweaking 6 15-05-07 12:46 PM
